	Threads: 465
114 Location: Cullompton Devon
 Car Model/Spec: Vauxhall
     Thanks: 1Given 98 thank(s) in 92 post(s)
		well as Tom has got a GTI6 had to go one betterso i have now spur of the moment purchased another 6 for myself
 my idea was to break it to keep my two 306 in parts but i think its to good for that
 i may save it and sell it on, but still undecided untill i get it home and look under it properly
 good bits
 straight clean shell
 w reg Ph3
 has a rebuilt top end
 toyo proxys all round
 after market exhust
 other than that it is a std car
 started first time after more than 12months
 bad bits
 been stood for over 12 months
 has a knock in one big end
 but was layed up as soon as it happened
 what do you recon its worth?
 1, as is?
 2, with new shells,cambelt and 12 month MOT?
 [attachment=21291]
	Threads: 386
87 Location: Suffolk
 Thanks: 1Given 118 thank(s) in 117 post(s)
		Hmm, Chris, JJ, now you...everyones buying cars, I'm feeling inadequate!
Big end knock is such a shame though, won't be worth much at all like that.  I would imagine around a grand with MOT and a decent engine though.  Depending on service history and mileage etc.
	Threads: 61
11 Location: Bury  St  Edmunds Suffolk
 Thanks: 2Given 41 thank(s) in 41 post(s)
		Hmm would love to see a track manstone
Just put the engine you've just rebuilt in it.
	Threads: 581
195 Location: Bournemouth
       Thanks: 36Given 82 thank(s) in 78 post(s)
		IF you can get away with just putting a set of shells in it, you can have that fixed in less than an hour. If it's got a rebuilt head, I'd imagine it will be a snapper which will be why the bottom end has gone.
	Threads: 465
		why are the bottom ends likely to go after being a snapper?
	Threads: 386
		An hour for replacing a set of big end shells!?  I wish I worked at Nialls pace!
	Threads: 581
		 (24-01-2015, 07:02 PM)Toms306 Wrote:  An hour for replacing a set of big end shells!?  I wish I worked at Nialls pace!
It's easy. Jack car up, sump off, plate off, oil pump off, remove big ends and replace, retorque (important bit lol) and put back together.
  (24-01-2015, 06:59 PM)cully Wrote:  why are the bottom ends likely to go after being a snapper?
I don't know but if you read around the 6 forum, they just always have!!
	Threads: 386
		Lots of things are easy in theory...its NEVER that easy in practice!
An hour has probably gone in the time its taken to find the tools, position the car, jack it up and drop the sump.
	Threads: 581
		It is that easy. I've done it my self haha
	Threads: 386
		Well I suppose you should be used to it by now.
	Threads: 465
		on rampsdrop oil
 drop sump
 remove oil pump
 remove windage plate
 unbolt caps
 remove shells
 hardest part is cleaning the gasket faces and working while on your back
	Threads: 386
		I didn't say it was hard, just don't see it being that quick!
Working on your back is the worst part, everything feels heavier and takes more effort lol, not to mention you'll be getting oil dripped on your head.
	Threads: 6
1 Location: Buxton, derbyshire
 Car Model/Spec: Yes, lots!
 Thanks: 1Given 2 thank(s) in 2 post(s)
		It's worth scrap money as a complete car IMO. I can virtually guarantee you won't get away with replacing the shells, do you not agree Niall?!
	Threads: 581
		I wouldn't want to say yes or no for certain without seeing the extent of the damage but the chances of you not having to have the crank out is very slim. You never know though, stranger things happen!!
	Threads: 91
83 Location: Oxfordshire/Cornwall
		Seriously, if the big ends have failed, putting in new shells without doing something that will stop it happening again, I can only see it happening again and again! You could spend a fortune on bits for it and be left in the same situation.
 I've got a spare GTi6 motor on 105k or so, bits like manifold, alternator/pas pump missing off it, but it is an entire motor, not a snapper, one out of my old car, needs a belt replacement and probably a bit of a clean, but it's a super tidy motor underneath if you are interested.
 (16-05-2016, 10:45 AM)Toms306 Wrote:  Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in. Nanstone GTD5 GT17S - XUD9TE
	Threads: 476
81 Location: Ipswich
 Car Model/Spec: 306 Rallye
 Thanks: 4Given 104 thank(s) in 102 post(s)
		is this a mid life crisis? but instead of buying a sports car youve just bought all the gti6s near you?
	Threads: 68
4 Location: Holbeach, Lincolnshire
 Car Model/Spec: 306 HDI
 Thanks: 0Given 1 thank(s) in 1 post(s)
		how come i been looking for ages and cant find any and its like a walk in the park to you :/
 if you sell / break id be interested not to jack the thread
	Threads: 465
		ive been looking a while for another to keep my fleet on the roadbut the one ive found maybe too good to break,
 but until I get it home and have a good look over it I wont make my final decision
	Threads: 164
25 Location: Honiton
 Car Model/Spec: Gti6
 Thanks: 0Given 4 thank(s) in 4 post(s)
		I've still got my old engine knocking around Paul
	Threads: 465
		did you end up stripping that one rocker to find the fault??
	Threads: 386
		 (25-01-2015, 03:55 PM)mspdan Wrote:  how come i been looking for ages and cant find any and its like a walk in the park to you :/
Because you want a decent one and Paul bought a broken one...
There are loads on ebay atm though!
	Threads: 68
		 (25-01-2015, 04:26 PM)Toms306 Wrote:   (25-01-2015, 03:55 PM)mspdan Wrote:  how come i been looking for ages and cant find any and its like a walk in the park to you :/
actually ill have you know Thomas i dont mind a broken one
haha might have gone one better anyway hopfully this week so ner
	Threads: 386
		One better?  You didn't buy the moonstone for £2.5k did you?
	Threads: 68
		 (25-01-2015, 04:30 PM)Toms306 Wrote:  One better?  You didn't buy the moonstone for £2.5k did you?     very funny...
no no no, you will have wait see as not set in stone and dont want it to fall through
	Threads: 386
		Fair enough then, I'll just have to wait.
	Threads: 68
		 (25-01-2015, 04:33 PM)Toms306 Wrote:  Fair enough then, I'll just have to wait.
wait for the project thread and my immense swearing
	Threads: 164
		 (25-01-2015, 04:15 PM)cully Wrote:  did you end up stripping that one rocker to find the fault??
It's missing a few parts but never got fully into the strip down so it's currently still sat in the shed
