Threads: 476
81
Car Model/Spec: 306 Rallye
ive never had any luck with any cheap set. Definitely dont buy cheap.
Threads: 14
7
Given 5 thank(s) in 5 post(s)
I got a set for 20 quid from my local nut and bolt place, has done a fine job for me so far.
Threads: 127
33
Car Model/Spec: ZX Volcane TD
id prob just buy high quality individuals of the ones you need and buy as and when to build up a collection - they are a proper pita if they snap in something you are trying to thread, and can be an absolute pig to get out.
Threads: 117
119
As above tbh, that clarke set will probably cover 80% of your needs, add a couple of larger ones and the usual bsp and npt and you'll be away.
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
Thing is it's like £6 a pop if not more for one tap.. Not exactly inexpensive when needing new ones, espically when you don't know for certain what pitch the threads are.
Threads: 41
3
Car Model/Spec: 306xrdt ph1
Given 4 thank(s) in 4 post(s)
I have a clarke one and broken a few of teh dies.
I bought some taps from aldi and they came with teh drills too which is handy.
Aldi or lidl had an offer on a couple of weeks back for a tap and die set which was reasonable. Dunno about M16 tho.
Threads: 117
119
Aye, and for the two or three extras in that larger set that you'll actually use it effectively works out as about £20 a tap, bargain...
I picked up a blue point set on offer recently, can't remember how much it was, but it's lifetime guaranteed, definitely cheaper than that bigger one you listed, has a similar range to that clarke one with two of the most common npt and bsp sizes and a thread gauge added in.
Also, when buying new taps and dies, why can't you just measure the thread pitch that you want to cut, rather than guessing and hoping?
Threads: 4
Given 1 thank(s) in 1 post(s)
Country:
I have a sealey set, covers most things I need, used it to tap a required thread in my Audi gearbox. Also got matching helicoil set, highly recommended
Threads: 541
124
22-01-2015, 07:51 PM
(This post was last modified: 22-01-2015, 07:52 PM by Dum-Dum.)
I have a small sealey or clarke or similar set that cost about £15 and has M4-M12 taps and dies plus the holders and a thread pitch gauge. I've had it for 5+ years and never had an issue and the only stuff I've had to buy to add to it are a couple of BSP taps and M12x1.25 which is the peugeot wheel bolt thread as standard M12 is M12x1.5
I wouldn't go for a big set as you are highly unlikely to use 90% of it. If I were gonna buy another set it would be a relatively limited set but one that came with primary, secondary and butt taps and the appropriately sized tap drill.
If you are just tapping out a hole that has previously had a thread in it then cheap taps are fine, people f*ck taps by trying to force them to cut, turn them forward a quarter turn tops and then turn it back by an 8th. Also WD40 is a tappers friend.
Threads: 41
12
Car Model/Spec: Dtractor
Given 6 thank(s) in 6 post(s)
Yeh as above really, buy quality sets you don't want a tap snapping off in a hole.
That said, I took the risk and bought a super cheap M3-M14 tap and die set for £20 on ebay, and have never had an issue. I dont use it often but when I do I'm really really cautious with it, and usually only use it on mild steel. For a 'one off' hole for a small project they can be great but have always been prepared or it to fail.
Threads: 41
3
M16 ? For the oil feed by chance ?
Just mention it as I'm looking at M16 to AN adapters on ebay.
Threads: 266
18
Cheers boys, will probably go for the Clarke set or similar then.
Na, not the oil feed Nominous.
