Fuel pump drawings none starter problem
#61
Did you check the voltage feed at the pump?
I haven't got any electrical testing kit available currently so i'm unable to continuity check or even voltage check anything Sad
Talk about working blind eh!
Relay etc looked all ok but gonna replace it as a matter of course. i have been told too check the fuel pressure sensor on the fuel rail also?
Team Cyril
#63
Have you got access to planet? Really is useful to see what's kicking off regards to pump pressure etc.
#64
No access too pug planet currently Sad
Team Cyril
#65
I've yet to see a rail pressure sensor actually cause problems, despite being a seemingly popupar scapegoat. You won't be able to test it without a multimeter or pp2000 anyway. I would check the connections though, especially the yellow plug that clips to the block just below the starter, i didn't think of that the other evening.
Regarding the lift pump feed, you could just use a bulb - fluctuations in voltage will show up as the bulb dimming and brightening. It should be a straight 12 volts, so the light should be steady.
I have managed to find a good HDI at work i can strip for parts, so far my list is:
HP pump inc solenoid
Fuel rail
Injectors
Anything else i should pinch off it before it goes in the crush?
Team Cyril
#67
All the looms lol, particularly door and engine, including the brown relay. Nothing else i can think of with regards to fuel related stuff though.
my lift pump doesnt sound as strong as any hdi i've ever heard and tbh i hate fault finding on diesels, anyone fancy being paid to fix it?
Team Cyril
#69
I would come and help you sort it, but you're properly miles away mate. Sad
Ok so its looking increasingly like its an injector fault possibly?
Fired it up yesterday, took around 50 seconds of non stop cranking before it eventually chugged into life, very smokey (white-unburnt diesel kind) and was misfiring until it had ran for a minute or two. then it was misfiring when revved
Team Cyril
#71
silly question as i haven't read all the thread does it start easier with easy start?
not that i enjoy using it but just a thought?
#72
Sounds like it could well be injectors... You really need to get some sort of diagnostics on there dude, that or get pro with a multimeter, we're just groping in the dark here.
Ah c'mon poodle abit of groping in the dark can be fun right? Tongue
TBH ive barely looked at it since it broke down, just tried the common stuff which didnt fix it so now its sat on the drive and im using the Rallye lol
I havent got the time or patience to spanner diesels so its going to my mates garage this week with a spare set of injectors, FPR, fuel rail, HP pump and crank sensors etc hes gonna work on it on the after 5pm tariff Wink he has full diagnostics so will have a much better idea than me Smile
Team Cyril
#74
the only difference between this and your rallye is the fuel pressure sensors and hp pump, lack of sparks too Big Grin
the rallye is also a sequentially injected commonrail system...
how about replying to your pm's anyway :p
#75
(20-01-2015, 08:27 AM)welshpug Wrote: the only difference between this and your rallye is the fuel pressure sensors and hp pump, lack of sparks too Big Grin
Yeah but the rallye runs on proper fuel Wink
Shall check pm's now dude, only get the forum at work so have to be fast as i can before the boss comes back in the office lol
Team Cyril
#76
Haha well, when you put it like that... Makeup
Fair enough mate, let us know how you/he get on.
  Increasing fuel pump output? JTaylor2005 7 4,489 06-06-2016, 10:00 PM
Last Post: Ruan
  HP Fuel Pump FPR Bolts BiG K 13 6,751 30-05-2016, 06:30 PM
Last Post: pug306driver
  Removing Hp fuel pump Welshy_Pete 8 4,856 24-05-2016, 01:42 PM
Last Post: toseland
