03-01-2015, 03:35 PM
106 Track Toy
03-01-2015, 03:44 PM
Comming along very nicely mate
Personally think you should keep it flat arch. ![]() Astor 6 Fast road/track project
03-01-2015, 03:48 PM
Yep save time,money and weight
![]() Can also get some '14' rallye steelies and they wouldn't look stupidly small. ![]() Astor 6 Fast road/track project
03-01-2015, 04:12 PM
03-01-2015, 04:35 PM
What are the plans for the heater matrix? That's going to make it really hot in the cabin in the summer.
03-01-2015, 04:46 PM
(03-01-2015, 04:35 PM)DeeTurbo Wrote: What are the plans for the heater matrix? That's going to make it really hot in the cabin in the summer. If you bypass it, remember to restrict the flow so as to not encounter heat issues within the cooling system ![]() ![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
03-01-2015, 05:24 PM
Probably going to bypass it with a hose Srowell found for me. And how can I restrict it?
04-01-2015, 06:03 PM
smaller battery, that will save weight.
04-01-2015, 06:29 PM
04-01-2015, 06:30 PM
(04-01-2015, 06:29 PM)Nathan1305 Wrote:(04-01-2015, 06:03 PM)procta Wrote: smaller battery, that will save weight. what you want to do pal, is rob an MGF for the battery cables, as the engine is in the rear on those and the battery is in the front.
04-01-2015, 06:34 PM
(04-01-2015, 06:30 PM)procta Wrote:(04-01-2015, 06:29 PM)Nathan1305 Wrote:(04-01-2015, 06:03 PM)procta Wrote: smaller battery, that will save weight. Like this? http://m.ebay.co.uk/itm/MGF-MG-F-TF-MGTF...0621970973
04-01-2015, 08:01 PM
(04-01-2015, 06:34 PM)Nathan1305 Wrote:yeah, see if you can get the negative one too, not sure where that went, as it was a long time ago when I broke my donor car.(04-01-2015, 06:30 PM)procta Wrote:(04-01-2015, 06:29 PM)Nathan1305 Wrote:(04-01-2015, 06:03 PM)procta Wrote: smaller battery, that will save weight.
04-01-2015, 08:04 PM
(This post was last modified: 04-01-2015, 08:09 PM by Nathan1305.)
(04-01-2015, 08:01 PM)procta Wrote:(04-01-2015, 06:34 PM)Nathan1305 Wrote:yeah, see if you can get the negative one too, not sure where that went, as it was a long time ago when I broke my donor car.(04-01-2015, 06:30 PM)procta Wrote:(04-01-2015, 06:29 PM)Nathan1305 Wrote:(04-01-2015, 06:03 PM)procta Wrote: smaller battery, that will save weight. It says it's the positive cable and negative cable from battery to starter motor. So I guess that all I need to move it to the boot (04-01-2015, 08:04 PM)Nathan1305 Wrote:(04-01-2015, 08:01 PM)procta Wrote:(04-01-2015, 06:34 PM)Nathan1305 Wrote:yeah, see if you can get the negative one too, not sure where that went, as it was a long time ago when I broke my donor car.(04-01-2015, 06:30 PM)procta Wrote:(04-01-2015, 06:29 PM)Nathan1305 Wrote: I want to relocate the battery Into the boot but not sure what gauge wire to get My mistake it is just positive so what negative cable will I need?
04-01-2015, 08:13 PM
you will need the positive, I think you will need a Univeral Negative lead, that will go on the earth side of things in the boot area, But you will need to earth what ever is on the negative lead in the engine bay.
04-01-2015, 08:25 PM
(04-01-2015, 08:13 PM)procta Wrote: you will need the positive, I think you will need a Univeral Negative lead, that will go on the earth side of things in the boot area, But you will need to earth what ever is on the negative lead in the engine bay. Cool so I need that positive mgf lead and buy some cable to make a negative and a distribution block. Is this a good guid to follow: http://www.seatcupra.net/forums/showthread.php?t=334161
05-01-2015, 05:38 AM
(04-01-2015, 08:25 PM)Nathan1305 Wrote:(04-01-2015, 08:13 PM)procta Wrote: you will need the positive, I think you will need a Univeral Negative lead, that will go on the earth side of things in the boot area, But you will need to earth what ever is on the negative lead in the engine bay. id see if anyone else on here has done a battery to the boot, and ask them.
06-01-2015, 04:29 PM
(This post was last modified: 06-01-2015, 04:31 PM by Nathan1305.)
[attachment=20985]
[attachment=20986] [attachment=20987] Did some tidying up of the wires today ![]()
Did do any/more stripping of the loom?
The luppy idling sorted now? ![]() Astor 6 Fast road/track project
06-01-2015, 11:02 PM
must be one of the first 106's ive seen with out seat mounts cracked! talking of cracked when you drop your axle asses the beam mounting areas as the body likes to crack and fail, ive seen it on so many just thought id pass it on.
07-01-2015, 08:56 AM
Dunno if it's already been said or done but take the spare wheel and the bracket for it off, take the inner arches out and blast out all the mud behind them to save a few grams
205 gti wheels are fairly heavy BTW might want to consider lighter wheels if your going to the effort of stripping the car Looking good and moving quickly at this speed when do you plan to have it finished?
Cherry red 205 XUD VNT - Project thread here http://306oc.co.uk/forum/showthread.php?tid=25522
07-01-2015, 03:09 PM
(06-01-2015, 10:50 PM)7057sam Wrote: Did do any/more stripping of the loom? Stripped as much as I could out, and it's kind of sorted haha I changed the plugs and it's helped, once it's been running 2-3 minutes it's fine but still revs lumpy on start up (06-01-2015, 11:02 PM)Stef205 Wrote: must be one of the first 106's ive seen with out seat mounts cracked! talking of cracked when you drop your axle asses the beam mounting areas as the body likes to crack and fail, ive seen it on so many just thought id pass it on. Cool thanks mate I'll check that out once I take the beam off (07-01-2015, 08:56 AM)andyyy Wrote: Dunno if it's already been said or done but take the spare wheel and the bracket for it off, take the inner arches out and blast out all the mud behind them to save a few grams The spare has already gone and that's a good Idea about the inner arches. What wheels would you recommend? And I should have it completely ready for FCS where it will get its maiden voyage ![]()
07-01-2015, 04:17 PM
Be great to see it getting hammered at combe,it's nice curcuit where car's with shorter ratios really thrive so you may get a few passes/keep with a lot of cars.
07-01-2015, 04:56 PM
Looking good mate.
Did the grill arrive?
07-01-2015, 05:13 PM
(07-01-2015, 04:17 PM)7057sam Wrote: Be great to see it getting hammered at combe,it's nice curcuit where car's with shorter ratios really thrive so you may get a few passes/keep with a lot of cars. Yeah I've been watching a lot of videos on YouTube and the 106 seems to love it round Combe (07-01-2015, 04:56 PM)JJ0063 Wrote: Looking good mate. Thanks mate and yeah it did! Looks so much better now [attachment=20998]
07-01-2015, 08:34 PM
id be starting on sorting out the handling now or engine tweaking.
07-01-2015, 11:21 PM
(07-01-2015, 08:34 PM)procta Wrote: id be starting on sorting out the handling now or engine tweaking. Getting a recon GTi beam from Stefan205 soon and some 50mm lowering springs for the front. That should give it some nice handling, then the brakes will be updated to 266mm. Unsure what I can do engine wise. It has a induction kit and a full pugs port system already
07-01-2015, 11:56 PM
id look out for some c5 steel/alloy wheels they are one of the lightest wheel combos out there at little cost.
08-01-2015, 12:23 AM
08-01-2015, 12:35 AM
the c5 wheels are lighter, if you go for 1.2's buy direct fit ones with the correct offset. Bloody spacers hate them with passion
