Good afternoon well the xsi went in for mot today and failed on the emissions. On second fast idle test the co is 0.56 and lambda is 1.090. But gutted but Iv put fresh oil and filter in and some redex in the tank. It's a fairly recent lambda sensor so hope it will go through this time!!! Had map sensor the other week too . Iv cleaned out breather hoses , tb and stepper motor any ideas what I could have missed?
Mot fail
30-12-2014, 05:27 PM
Air leak on the inlet side somewhere perhaps.?
30-12-2014, 06:16 PM
30-12-2014, 07:04 PM
This is of another forum im on may help with sorting it
Cars can fail the emission test for a number of reasons, could be down to using an open air filter/induction kit or could be down to using a sports exhaust. Some de-catted cars may pass, but this is due to the mechanical condition of the engine and how its been looked after. Alot of people say replace the cat, when infact it doesnt need a new one. Firstly check your emission sheet and see what readings are on it, or if you dont have one refer to the VT30 (failure sheet) High CO and Low Lambda... is rich mixture which is caused by a missfire, faulty oxygen sensor, blocked air filter High Lambda and high O2... could be the cat but check the oxygen sensor is working, there are no leaks in the exhaust, and could be caused by using an open air filter/induction kit, Air leaks in the intake system, faulty map sensor, could also be down to poor engine condition and maybe cured by a service High HC (hydrocarbons) ... with good CO probably a missfire, poor engine conition, with high CO fail and a low Lambda the mixture is rich CO high, lambda high and O2 high... cat faulty (or Intake leaks etc) Lambda fail... if a high fail faulty oxygen sensor, weak mixture, hole in the exhaust. if a low fail then faulty oxygen sensor, rich mixture or misfire Before replacing an oxygen sensor you can remove it and check it visually, and test it if u have the correct equipment
30-12-2014, 07:09 PM
CO is likely to be the cat though if the cat is got really hot it may pass, Lambda is usually out due to a exhaust blow
(30-12-2014, 07:04 PM)vincent1 Wrote: This is of another forum im on may help with sorting it Wow that's given me a lot to look into many thanks. Iv got all the readings from mot do I can get things rolling . Thanks again (30-12-2014, 07:09 PM)Frosty Wrote: CO is likely to be the cat though if the cat is got really hot it may pass, Lambda is usually out due to a exhaust blow I put a new cat on with lambda sensor about 3 years ago but have only just learnt that they don't really last that long!! So I have a list of things to try tomorrow then it's retest this Friday. If it fails then I will put a new cat on and also spend some time getting all the parts Iv gathered fitted. Ready for summer fun
30-12-2014, 08:07 PM
The cheap after market cats aren't very good tbh. They dont seem to last that long and they need to be got very hot to work as they should
Yay the 306 has got mot !! Turns out the cat was not purring anymore . So put new one on and now she's purring like s boss .
(30-12-2014, 08:07 PM)Frosty Wrote: The cheap after market cats aren't very good tbh. They dont seem to last that long and they need to be got very hot to work as they should That does seem to be the case mate but another cheapo had gone on . Sometimes needs must
02-01-2015, 12:40 PM
Get a decat to run between mot's to preserve the cheap cats lifespan??
Win win situation
02-01-2015, 11:57 PM
