17-12-2014, 09:52 PM
Anyone local to north London with a spare rear caliper left hand side?
Needed asap
Cheers
Needed asap
Cheers
Wanted | rear caliper left hand side
Needed asap Cheers
17-12-2014, 09:54 PM
what size piston?
17-12-2014, 09:57 PM
(This post was last modified: 17-12-2014, 10:02 PM by zx_volcane.)
Is there a choice?
Basically have a braking imbalance on the rear. Both handbrake and normal braking is down in one side, which to be suggests caliper rather than s hydraulic issue. Sliders are free, new discs and pads, and I've given them some death to bed them in Hmmm Anton had just pointed out that the parking brake is achieving more than the foot brake in the rear Bias valve? Don't suppose anyone has one of those as well - not a compensator but an inline valve
17-12-2014, 10:06 PM
those pressure regs are specific to the zx, I think the volcane used same as a 309 gti, 16v is higher pressure and a bigger 32mm piston (instead of 30mm)
17-12-2014, 10:46 PM
Good info, thanks, need to check piston sizes I've got on, might be a mix of 306 and Zx bits
It's on another volcane Td, though not mine
19-12-2014, 12:48 AM
I've got a pair of calipers on the xsara, think they are the same, I'm nowhere near london but I am driving down on the 27th and probably parking up at Stanmore tube station
19-12-2014, 09:23 AM
(19-12-2014, 12:48 AM)Sambarker Wrote: I've got a pair of calipers on the xsara, think they are the same, I'm nowhere near london but I am driving down on the 27th and probably parking up at Stanmore tube station Cheers Sam, hopefully getting it sorted before xmas, but will give you a shout if I'm stuck |
| Wanted: rear caliper | fgrc76 | 1 | 2,681 |
29-08-2018, 07:36 PM Last Post: Piggy |
| WANTED. side skirt clips. | NOSE | 0 | 1,729 |
05-12-2016, 07:09 PM Last Post: NOSE |
| Wanted: Right side rear caliper (Bought) | Iaitoo | 2 | 2,533 |
02-06-2016, 08:08 PM Last Post: insomaniac45 |
