Help - Drivers window!
Exclamation
Hey All -
Small problem, the glass in the drivers door has slipped off its runners. Is there a way to get it back on the runners without taking the door card off?
If I have to take the door card off, what is the best way to remove this from a 3-door p3?
Thanks in advance!
OK - found the card removal guide: http://306oc.co.uk/forum/showthread.php?tid=11609
Looks like I'll be doing that first thing in the morning!
YAY...! Sad
Door card takes about 2 min to remove buddy.
Theres three or four torx head screws iirc
the trim around the wingmirror adjuster (if manual or beblank if electric) would be to remove plus trim around door pull handle, screw under the window controls, two on the main grab handle, the rest is just clips so pull from bottom around sides then slide up off top seal
Thanks given by: mackat
You're a Star..!!
Looks like I didn't have to play around with the glass. Once the card and door trim was off, managed to slid the glass up. Looks like the door took a little more battering than I thought!
Smile
