11-12-2014, 09:18 PM
How many amps dose it take to power the glow plugs? Planning to make a coolant heater like the Hdi
Glow plug Amps
11-12-2014, 09:21 PM
How many plugs do you want to use? The glow plug relay on the xud comes straight off the battery, no fuse, so imagine all 4 draw a lot of current.
11-12-2014, 09:23 PM
surely its easiest to rob the heater and its relay from a hdi?
Its for a hilux, i suppose i could fit the Hdi one but i was planning to modify the original metal pipe to take 4 new glow plugs i already have for a Xud
What dose the relay for the standard hdi one lookilike? this is a simple split charge one i was planning http://www.ebay.co.uk/itm/12V-Heavy-Duty...4aca2c4780
11-12-2014, 11:03 PM
I'd suspect about 20A per plug peak draw when first turned on and settling to about 14A or so once up to temp... That gives a peak current of about 80A.
12-12-2014, 08:15 AM
Seems about right according to my back of fag packet calculations.
12-12-2014, 10:59 AM
Is the HDI one the two inline pipes with flanges bolted together??
I've seen that design on ebay. Good as it works with anything and everything. The passat has one fitted on the back of the head with 3 plugs. Just before the coolant goes into the matrix.
12-12-2014, 06:28 PM
Anyone got the pin out diagram for a standard glow plug relay? think its the 5 pin one i have
15-12-2014, 08:35 AM
I'm planning on putting a second set on my HDI so it warms up quicker.
I've got a set of the glow plug device and the associated cables with the relay box. The heater uses two relays as there are two heat settings. Both relays are fused with 40 amp fuses. I'll get some photos of it in a bit.
15-12-2014, 06:32 PM
15-12-2014, 06:48 PM
With decent plugs you should get heat in the cabin within a few minutes Dee, I don't think it's worth the effort adding another set as well?
15-12-2014, 06:51 PM
How hard its it to get new plugs for the standard Hdi heater?
15-12-2014, 06:55 PM
Impossible. They don't sell them singly so you have to buy the whole unit which is stupidly expensive. However, you could measure and try to find a similar sized plug to fit, Poodle was looking into it but I'm not sure if he found an appropriate set or not.
15-12-2014, 07:40 PM
(15-12-2014, 06:32 PM)nominous Wrote:(15-12-2014, 08:35 AM)DeeTurbo Wrote: I'm planning on putting a second set on my HDI so it warms up quicker. I think the HDI alternator has a 160amp rating but I have up rated cables because of audio gear. (15-12-2014, 06:48 PM)Toms306 Wrote: With decent plugs you should get heat in the cabin within a few minutes Dee, I don't think it's worth the effort adding another set as well? I'll have to check them and swap the units or make one good one out of the two units I have.
16-12-2014, 09:18 AM
The way they do this on more modern cars is that they have an electrical heater instead of heating the coolant. it's inline on the heater matrix. They are around a KW.
Found this in an old thread-
Poodle 04-12-2013, 06:26 PM Right, measurements on the standard plug for the pre-heater: Tip: 28.5mm Shoulder: 4mm Thread: 11.5mm (M12x1.25) Body: 23mm (only part exposed when installed) Total length: 67mm Body hex: 12mm Top nut: 8mm Dt plug measurements: Tip: 24mm Shoulder: 7mm Thread: 14mm Body: 27.5mm Total length: 71.5mm Protruding plug when installed: 33.5mm Thread and hex sizes the same as above.
17-12-2014, 12:12 PM
Quote:I think the HDI alternator has a 160amp rating but I have up rated cables because of audio gear. It won't do anywhere near that at idle though. 40-50A if you're lucky.
Previous Car: VW Passat 2.0 TDi 140, 2005, 136,000 miles Previous Car: Peugeot 306 XLdt (stock!), 150,000 miles (I miss this car )
17-12-2014, 01:32 PM
I use these for manual glow plug use. Works like a charm. | Dyno Power Runs & Steady State Facilities Available, Just Ask Anytime |
| #DervMafia | ![]() |
| Glow plug relay - help please | Pugmarshall | 5 | 5,351 |
13-01-2019, 06:27 PM Last Post: weka |
| rounded off glow plug | Chris_90 | 22 | 14,212 |
08-12-2014, 08:10 AM Last Post: Chris_90 |
| Glow plug light issue | Gaz85 | 1 | 2,424 |
30-12-2013, 07:36 PM Last Post: Gaz85 |
