MOT failure on brake hoses
Just picked my car up from the garage and both front brake hoses are a fail, it says - "Nearside front (fouling wheel) Brake hose has insufficient room to move, resulting in fouling on any part"
I have upgraded the standard dt brakes to gti so does this mean the hoses are to short and i need to get longer (gti) hoses?
Cheers!
No smoke, No poke!
mmmm just get some braided ones on there anyway?
There's two different length front hoses for 306's depending on caliper type fitted, so could be yours are the shorter type.
From memory, Lucas calipers (including GTi-6) use the longer hose.
Was thinking of upgrading to braided ones, wheres best to get them?
Just checked europarts and the hoses listed for my standard brakes are the same length as the ones listed for the gti
No smoke, No poke!
I never knew there were 2 different lengths front hoses. Are yours clipped in right?
As for braided lines just have a search on ebay
Not sure if they are clipped in properly, its rusted to f**k anyway so its being scrapped unfortunately
No smoke, No poke!
Afaik as I'm aware and all the books I have access to there is only one length line for the front
The rears have a couple of options
This problem normally occurres when the lines have been fitted incorrectly
Lucas 530mm
Bosch 515mm
Need I say more
Turns out its because the hoses had come out their clips, so out them back in and cable tied the B**ch to it!
No smoke, No poke!
Surely the tester could've just pushed them in if that's all it was. Confused
That's what i thought but that was probably to much work to do without being paid for it, exactly the reason i do work on my car myself....
No smoke, No poke!
  Brake pipe failure Mighty306 3 4,496 15-08-2020, 03:27 PM
Last Post: ekjdm14
  Cheaper Braided Brake Hoses Toms306 11 6,547 05-08-2016, 10:22 AM
Last Post: PocketFighter
  Where to get retaining clips for brake hoses? Spoonaltap 5 3,684 30-07-2016, 05:36 PM
Last Post: Spoonaltap
