Lightened flywheel and crank pulley
Yup, I was going to say that there's still some floating around that come up for sale every now and then.
What I suspect he means is that all those that resellers had on the shelf were replaced.
Every day is a school day, I will probs buy an item like that brand new tbh
i couldn't get out of him the difference in the two
other than
There's no way to tell them apart really - the ring gear are the same size, although the offset is different
i found out
early ones EN8D grade steel have smaller ring gear
later EN19T chromoly steel have a larger ringear
i was trying to work out if the one i bought was an early or later
anyone else shed andy light on the differances
i believe the timming mark teeth are cut square on one and have a triangle airspace profile on the other but i bont know on the version for each
(20-11-2014, 07:21 PM)cully Wrote: i couldn't get out of him the difference in the two
other than
i found out
Easiest way to tell is the noise it makes when you start it. If it just sounds like a stock engine when cranking, its a later one. If it sounds completely different, its a early one although did you not buy yours new when you first got the 6? If so, it will be later as IIRC the first gen ones were stopped bloody years ago.
bought it second hand and its still in a box in the shed Wink
Ah in which case i wouldn't know. Im sure there is a visible difference but i wouldn't know what!
Use a diesel starter on the gen 1 iirc
P1 XSi track car
2.4 LWB T4
  Lightened flywheel Niall 10 5,358 17-11-2013, 10:36 PM
Last Post: Niall
