Ignition feed to radio
Which colour cable going to the radio is ignition live or whatever it's called?
Want to take a feed from it so gauges only use power when ignition is on. I was going to use a live feed with a switch but would rather use ignition if possible.
Cheers!
[Image: 66800570c1f2a2873f1cef8c9570bb74.jpg]
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
I can't remember the colour off the top of my head. Don't you have a multimeter handy?
[Image: ISO1.gif]
That is looking at the back of the radio
Yeah I have a multi meter, stick in in a plug, turn ignition to, measure voltage, rinse repeat? Surely they all see voltage when ignition is turned to?
Cheers Dan, so that would be... no 4... Uhh... Yellow? Big Grin
S14 Zenki Build
Ahh. I needed an ignition live to wire mt radio in my new one. It only has two permanents onmine. Tried moving fuse then had nothing. So gave up and wired it to live. Cbe for messing about.
Btw for the gauges there are plenty of ignition lives elsewhere if need be. Smile
(17-11-2014, 03:07 PM)bashbarnard Wrote: Ahh. I needed an ignition live to wire mt radio in my new one. It only has two permanents onmine. Tried moving fuse then had nothing. So gave up and wired it to live. Cbe for messing about.
Well all my cables are coming out the dash above the radio so thought would be easiest to take from there.
What wires else where can I use then? Never messed about with cutting wires at the ignition barrel so would appreciate in depth "dummy" advice.
S14 Zenki Build
Bottom Iso, pin 4, Connect your gauge up and test it
How many gauges are you using? Surely it would be better to use the ign+'Ve from the barrel? Less stress on the wiring if you have a few gauges then too Smile
Err. Currently there is 4. There will likely be 7 in the future.
Currently have: Oil pres, oil temp, EGT, boost.
Would like to get: water temp, additional boost, EMP.
Not all of these require a live and the light live is coming off the side lights.
So which cable is the ign+ at the barrel Grant?
S14 Zenki Build
You're the man with a multimeter. I'm on the underground! Haha.
Have a pone around and see what comes live with the ignition Smile
(17-11-2014, 03:34 PM)Grant Wrote: You're the man with a multimeter. I'm on the underground! Haha.
Lol! Blush
S14 Zenki Build
  Radio/Arial + radio stalk PocketFighter 15 9,560 05-08-2016, 08:16 PM
Last Post: PocketFighter
  Radio ignition live Dean 3 2,528 27-11-2013, 05:54 PM
Last Post: DTurboTom
