Sump oil temp plug
Sump oil temp plug
Afternoon All
has anyone monitored there oil temp from the sump? or is it not do able on the 306 cause the thread pitch being M14X1.25 is a bit out there
(07-11-2014, 03:31 PM)pugdan95 Wrote: Afternoon All
the 306 gti6 oil temperature sensor is m14 x 1.25 and the HDI sump plug is m14 x 1.25 so if you have 2 sump plugs (i know i have) then you should be able to use the upper one a "6" sensor (or a after market one) as your oil temp then you would just need a gauge to read the sensor
Jake
Jake
Yeah I've got too sump holes would this adaptor work with a 1/8 npt temp sensor screwed into it?
http://www.demon-tweeks.co.uk/performanc...t-adaptors
Jake
In theory yes as the outer thread will be the sump size and the inner the sensor size, but in my opinion a m14 sensor would be better but thats just me Smile
Jake
(07-11-2014, 10:54 PM)306clot Wrote: the 306 gti6 oil temperature sensor is m14 x 1.25 and the HDI sump plug is m14 x 1.25 so if you have 2 sump plugs (i know i have) then you should be able to use the upper one a "6" sensor (or a after market one) as your oil temp then you would just need a gauge to read the sensor
Jake
Jake
Getting hold of a M14 sensor it's a bit hard and a gti 6 one is 55 quid just for the sensor think il go with a couple of adapters
Just get a second hand sensor? In fact i may even have one here you can have for £10 posted.
(08-11-2014, 08:33 PM)Niall Wrote: Just get a second hand sensor? In fact i may even have one here you can have for £10 posted.
And that one would just screw in and then I'd have to wire it up? Fully working niall?
Let me check the shed tomorrow but yes. its a standard GTi one so yeah, should be fine!
Nice one if could have a look tomorrow for us and let me know if you've got one that would be great Smile
  Swapping 3 plug to 1 plug bashbarnard 6 4,410 25-02-2017, 05:16 PM
Last Post: bashbarnard
  Intake temp and Exhaust temp sensors? JTaylor2005 5 4,291 26-12-2014, 02:04 PM
Last Post: JTaylor2005
  306 HDI sump plug size boggs 4 3,063 05-02-2014, 05:55 PM
Last Post: Slam Wagon
