Galletto Connection Issues... (and now MPPS queries...)
24-10-2014, 03:36 PM
OBD loose? connections are always a bit dodge arent they?
24-10-2014, 03:39 PM
Seems pretty solid tbh, and I don't have any issues connecting the ELM cable so I think it's possibly a software issue or more likely user error lol.
25-10-2014, 10:22 AM
Anyone else?
25-10-2014, 03:09 PM
Bring to garage ill pop our diag on at dinner and check if you want.
25-10-2014, 07:24 PM
Thanks for the offer but what are you gonna check? The OBD port is fine, I have the ELM plugged in every few days lol.
25-10-2014, 07:42 PM
Just thinking if yours doesnt read mine might. Just to rule it out man.
It's only the Galletto that doesn't read, everything else does. Unless you've got any mapping cables? MPPS or KWP or anything?
Also, not sure if it means anything but the Galletto plug flashes red and green while it's trying to read?
25-10-2014, 08:55 PM
I don't like Galletto for this reason - more issues than success in my experience.
MPPS all the way.
JP
26-10-2014, 08:45 AM
Bin it and get an MPPS. Friend if mine has been through like 5 gallettos and my first mpps is still absolutely perfect. Only paid like 12quid for it!
26-10-2014, 09:38 AM
I've mapped loads of VAGs and HDis with this galletto, original one since 2012 without issue so far lol. Suppose I could get an mpps as well though!
29-10-2014, 03:14 PM
Solved the issue.....got an MPPS instead.
But it takes a lot longer than Galletto....10 mintues to read! ![]() But now I'm confused, the file it's saved is 2000(ish)kb. I thought map files were 512kb? ![]()
29-10-2014, 03:19 PM
Depends on the car/ECU mate, although that sounds pretty high
In terms of it taking 10 mins to read, there's normally a slow/fast setting? or at least there is in KWP ![]()
29-10-2014, 04:27 PM
Can't speak for the Focus, but the MPPS takes less than a minute to read the data off a 306 HDi (EDC15) ECU
If the file is larger on your ECU then I'd expect it to take longer to read, but 10 minutes does sound like an awfully long time.
29-10-2014, 04:36 PM
Hmm...
29-10-2014, 04:45 PM
Tom, that's right. Later ECUs have more in them so the file is bigger. Remember, its not just a "map" in there. There's tonnes of info in it.
Some ECUs take ages to read, take the ECU in a JTD Alfa, 45 minutes to pull off a 2meg file, and then about 3 minutes to write back!!
JP
29-10-2014, 04:59 PM
45 mins? Surprised the battery lasts long enough lol.
![]() So this file will be fine to send to you then, yeah? ![]()
29-10-2014, 05:03 PM
Ah that's good then!
Maybe I just worry too much. ![]() |
