Threads: 42
2
Car Model/Spec: Astor GTi6 P3
Given 2 thank(s) in 2 post(s)
In the process of wiring up a JBL GTO-4000 to a Pioneer mvh-160ui - When I switch the HU on, the amp powers up then almost immediately switches off.
I've tried connecting the remote cable directly to the + on the amp but again the same thing, powers on then immediately switches off.
Any thoughts on what to try next?
Threads: 7
Have u got a good enough earth connection?
Threads: 42
2
I've got the earth going through one of the rear seat bolts - Then tried another bolt hole in the front passenger foot well. - But you might be right, I'll try filing down the metal work on the rear bolt and try again..
Threads: 183
20
Given 8 thank(s) in 8 post(s)
You have the remote connect to the positive on the amp? It needs to be connected to the remote connection usually inbetween power and ground
Threads: 476
81
Car Model/Spec: 306 Rallye
Put all the cables in the right place. Its probably the earth as others have said. Where is your amp located? Normally we all put them in the boot so you must have it somewhere different or you must be running a massive earth if you are earthing it in the seat bolt or the passenger footwell.
Threads: 7
When I had my amp in my volvo I earthed it through the rear seat bolt but I cleaned the metal up first so I knew I was getting a good connection
Threads: 42
2
Per usual I dropped off the internet..
Just wanted to say thanks for everyone's help with the ice problem, the seat bolts weren't grounding properly (even after attacking them with a dremel) - Ended up grounding to the body just inside where the rear lights are.
All perfect...and very happy!
:o)
