24-10-2014, 02:53 PM
Really? Job for Sunday then, should be fun
Gear Linkages Fitting Guide?
24-10-2014, 03:08 PM
(24-10-2014, 02:36 PM)silverzx Wrote:(24-10-2014, 02:23 PM)LewisG Wrote: I don't how you make it sound so easy, I can only see 2 and you can't even see the other end so how do you get the clips in if you can't see the other end Yep this, and I found it a bitch! Glad it's out the way
24-10-2014, 04:57 PM
(24-10-2014, 03:08 PM)DazzaHDI Wrote:(24-10-2014, 02:36 PM)silverzx Wrote:(24-10-2014, 02:23 PM)LewisG Wrote: I don't how you make it sound so easy, I can only see 2 and you can't even see the other end so how do you get the clips in if you can't see the other end Not looking forward to it tbh, best get it out the way though
Its easy tbh...getting the clips in is the hardest part if you're a clumsy bugger like me, prepare for several minutes spent looking for dropped clips on the driveway.
24-10-2014, 06:17 PM
24-10-2014, 06:21 PM
What do you need to see? Just feel your way around...
24-10-2014, 06:26 PM
I have this to do on my HDi, but I have been putting, and putting it off. As I wasn't sure on how to remove them, i can see it been a f*ck on for me sadly.
24-10-2014, 06:28 PM
My only worry is, i get the old ones off and cant get the new ones on lol the clips are going to be the hard bit
24-10-2014, 06:43 PM
Lol, it'll be fine. Bet you'll do it in half an hour and wonder what you were worried about.
25-10-2014, 07:29 PM
This is something i need to do, fair bit of slack when in gear
26-10-2014, 11:48 AM
Well I fitted the gear linkages, Wasnt that hard, to be honest the hardest part was getting the old ones off, but using a spanner worked a treat, thanks guys! Realised how bad my oil leak is, the back of the engine is soaked, its engine oil, but the level doesnt seem to be dropping so im stuck on that one
29-10-2014, 08:25 PM
(26-10-2014, 11:48 AM)LewisG Wrote: Well I fitted the gear linkages, Wasnt that hard, to be honest the hardest part was getting the old ones off, but using a spanner worked a treat, thanks guys! Realised how bad my oil leak is, the back of the engine is soaked, its engine oil, but the level doesnt seem to be dropping so im stuck on that one Probably a minor leak that hasn't been cleaned over many years? I thought i had a major injector seal leak until i degreased the engine and realised it was relatively minor |
| Miles Solid Gear Linkages Video | wainwrightj | 7 | 8,416 |
02-02-2018, 08:40 PM Last Post: wainwrightj |
| Anybody fancy fitting a 5th gear synchro? | Iceman299 | 8 | 5,791 |
11-02-2015, 12:53 PM Last Post: Iceman299 |
