darrenjlobb's Rolling Road Chassis Dyno Project
#31
maybe you need to look to america as that is where your rollers came from i believe Wink
That's what I meant Darren, machine both so they are the other way round, even if you have to carefully weld a sleeve or something similar in to the housing and machine out the shaft. It may be the only way to do it
/Toseland
(19-10-2014, 09:44 AM)cully Wrote: maybe you need to look to america as that is where your rollers came from i believe Wink
Heh I have searched the states as best as I can also...and several UK resellers have been in contact with there American suppliers, to no avail...
[Image: sigi-2.png]
i am just thinking...
differential seals on the suzuki are "sprung outer" like the (driveshaft seals either side)..
might be worth a look at some truck part supply places for older military vehicles? i should imagine something like the Alvis Stalwart will have an odd, imperial, configuration.
/Toseland
Dont you have a lathe? couldn't you machine some up?
Looks epic so far,keep up the good work Smile
[Image: Cn91r40h.jpg]
No lathe here at the moment, will find one locally one day, but for the time being sadly I dont have one...
Most vehicle things are just normal lip seals in general, other than water pumps which have a basic mechanical seal in them...
[Image: sigi-2.png]
http://www.waterworld.com/index.html give these guys a poke, see if they can help
/Toseland
Bit of a boring update, but have "fingers crossed" got my shaft seal solution sorted, after speaking to various people with the same unit , I quickly came to the conclusion that I simply wasnt going to find a replacement off the shelf seal, they literally just dont exsist, So decided to figure out a way to retro fit a modern seal, which from using parts from various seals and modifying housing / shaft and the collar, I THINK ive figured a way to make it work, not finished the concept yet, but will hopefully know by the end of the week, need to machine some parts down before I can put housing over and find out!
So in the mean time have started doing some prep in the workshop to make it fit, anyway who has had any work done with me before / come and payed me a visit will know, that I dont have a posh fancy workshop, or any of that, its literally a disused calf shed (I used to rear calves in this very shed when I was younger) which I took over, and has converted itself into my workshop. So its not ideal, but it does what I need it to do. A few years ago me and Chris dug / built a pit, and made a "hole" in the wall so you could drive through.
It has served its purpose well, but one pain with it, is when there is a car over the pit, the opening is only just wider and the car, resulted in lots of squeezing past / wing contact, and just generally no room to work...
A picture before...: (also anyone that visits recently will be shocked with how much stuff ive had to move to "clear" this area!!
[Image: IMG_20141102_110954.jpg]
[Image: IMG_20141101_195542.jpg]
So started by marking where we wanted to extend to, and just stitch drilled down through to make a "brake away" point:
Removed the old frame we made last time and "propped" the roof up, couldnt find the props so out with the old door frame and a spacer Tongue
[Image: IMG_20141102_114201.jpg]
Bit of a clear up:
[Image: IMG_20141102_122633.jpg]
Decided to remove the extra wood in the roof and butt our new truss right up to the top, gave us an extra 5 inchs of headroom, which means i can walk through without banging my head (Dont get excited Ruan, your still f*cked chap Tongue)
[Image: IMG_20141102_143417.jpg]
Banged up new frame:
[Image: IMG_20141102_152803.jpg]
Then set them in concrete / back filled the gaps with cement, but forgot to take a photo of that. So now plenty of room to walk around the car, and also plenty of room in the event of a dyno strap fail to prevent cars smashing into the walls!
No, its not a professional job, but its only ever been a "temporary" workshop to be honest, I just keep spending the money I need to build a proper purposed one on making more boost, but maybe one day, It's far from ideal but it gets the job done and many things have been created under this roof!
[Image: sigi-2.png]
Looks great. Good progress! Haven't been down to lobby land yet but maybe I'll be down again in a few years time by which point you may have just fixed the seal problem lol.
Jealous of your workshop tbh. Id be more than happy with that!
Good work fella Smile
Looks like you've got a great space there only slightly jealous! will be mega when you get your rolling road sorted out.
Beats my gravel drive!! lol
(02-11-2014, 10:05 PM)Piggy Wrote: Beats my gravel drive!! lol
Haha there the worst changed a clutch on gravel once worst idea!
Nice to see a different project going on and will be good to see when it's all done
Workshop looks brilliant
Workshop looks amazing. Looks huge when its tidy. (mine looks twice the size tidied too though)
but can it beat an evo? =D
I have a nice reliable figure for mine Darren.. so if you want me to come down and give you a calibration vehicle other than your own (and your tractor) I would be more than happy to obligue..
might require you to help me fit my FMIC at some point as well lol,
/Toseland
Gave the frames a quick paint up tonight. Was going to have them shot blasted and then spray them up, but the guy who was going to shot blast them didnt have time, so I just picked them up, cleaned them up and painted them up, save some money and not going to make any difference really Smile
Wanted to maintain the original Yellow that Clayton made them, but of course, I had to use the nearest substitute, Deere Yellow Smile that being said, the colour is near enough identical to the original Clayton colour where it hadn't faded underneath things!
[Image: IMG_20141104_195642.jpg]
[Image: IMG_20141104_195648.jpg]
[Image: sigi-2.png]
That. yellow. is. Epic! if it's as bright as it looks on my screen... that's exactly the colour i want for mine Smile
workshop looks brilliant, so much want for something like that one day
Project: Formula Peugeot
Niceeeee! So you gonna be digging holes for the roller to go in or what's the plan?
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
Yeah will be digging a hole in front the pit there, exhaust fan out the rear wall, with car pointing toward the camera...
But have to refrain from doing that, as I need to "drop a cummins in a landrover" next week, so dont want to restrict pit access!
[Image: sigi-2.png]
Is that wiring looms in the left hand corner..?
S14 Zenki Build
(04-11-2014, 09:20 PM)darrenjlobb Wrote: Yeah will be digging a hole in front the pit there, exhaust fan out the rear wall, with car pointing toward the camera...
lol, finally get fed up with the 300tdi leaking oil?
/Toseland
(05-11-2014, 08:46 AM)silverzx Wrote: Is that wiring looms in the left hand corner..?
It is, can always find the connector you need in that lot somewhere Tongue
Haha yeah, and head gaskets going, and its just generally worn out!
[Image: sigi-2.png]
Rolling road day at darrens it is! Big Grin
(04-11-2014, 09:20 PM)darrenjlobb Wrote: But have to refrain from doing that, as I need to "drop a cummins in a landrover" next week
As you do! lol
(04-11-2014, 09:20 PM)darrenjlobb Wrote: I need to "drop a cummins in a landrover" next week
Now that is a project. I want one!!!!!!!
6BT?
would be interesting to see the difference in weight between the TDI lump and the cummins
240kg difference
[Image: sigi-2.png]
  Reinstate The 25Year Rolling Road Tax Exemption Uberderv 9 4,735 21-02-2016, 09:15 AM
Last Post: welshpug
  Rolling road near darlington mossy1985 5 3,255 20-11-2014, 01:18 PM
Last Post: mossy1985
  FAO Anyone trying to contact the farmer (darrenjlobb) Tom 10 6,273 23-02-2014, 09:16 AM
Last Post: Atterz
