Wanted: lowering springs -60mm
as above, doesn't matter what they look like, cheap would be an advantage, dampers? whyg
Smile john
Project: Formula Peugeot
If you're sticking with your original shocks, personally I'd advise only going as far as -40mm...I had -60mm springs coupled with the standard shocks on my DT, and Niall will agree that it ended up very crashy and quite uncomfortable. If you DO go -60mm, get some uprated shocks. Wink
yeah for sure.
I would try -40mm first if I were you, be surprised how low 60mm is. And the back end on your car John doesnt look like a 60mm drop!
my thoughts are if there's some 60 springs for say a hdi or gti then they won't lower nearly that on the little 1.4, otherwise yeah i suppose 40mm would be enough
Get 40s. Even that is too much really for standard shocks. Even B8s which are designed for a shorter spring are only designed for 40. Any more and you start to loose damping basically which makes it very sketchy and no fun to drive.
Well the DT was fun to drive, just not round the roads near Grant's place! lmao
Or be irish, and dangerous, and get saxo springs?? lol
LOL nope, not going there, prefer my cars safe thanks Tongue
saxo springs was fine on my hdi estate wheels tuched the arch alittle bit from time to time and it looked like i was drunk missing the pot holes normal day no? Big Grin
Saxo springs, as mentioned and as stated in their title, are for saxos. Not 306s. You are making your car dangerous by fitting them.
I've got a set of Xsara VTS ~50mm lowering springs if they're of any interest?
I got them to try on my 205 GTI-6 as 205 springs don't deal too well with the additional weight, but I didn't end up using them so they're now surplus.
VTS strurs arent a bad call as they are slightly shorter I believe.
Although 1.4-gti weight is quite different, no?!
Love how a thread for "wanted - lowering springs" has turned into a "don't do this, you should do that" thread
How about just keeping it on topic?
  306 lowering springs floz123 3 3,939 21-04-2017, 06:34 AM
Last Post: ozonehostile
  Wanted: Hdi Lowering springs ct-hdi 3 3,220 06-02-2016, 05:44 PM
Last Post: WiNgNuTz
  Wanted: D Turbo 50/55/60mm springs Dazecoop 4 3,308 05-02-2016, 05:10 PM
Last Post: ginge191
