Stage 2 Maf problems?
Right.
Current mods are free flowing exhaust system, egr delete, 2.25" to 3" fmic, air-con delete, 1.5 bar on stock turbo, cg ceramic paddle clutch, ram air cone filter and a stage 2 whippy map.
[attachment=17991]
I've recently realised that if I unplug my maf I seem to be getting better fuel economy and running quicker than if I have it plugged in. Is this shouting out naffed Maf or just the fact im lacking a decent cold air feed in our recent warm weather?
Justin_306DTurbo
306 Ph1 Dturbo Sedan
306 Ph1 Dturbo Estate (VNT)
Partner Ph1 (XUD Swap)
306 HDI Stage 3 Estate (RIP)
Sounds like the MAF is shot, but it probably would run even better with a stock airbox with the cold air feed as the cone will be sucking in a fair amount of hot air off the rad
Busted MAF. Either replace it with a known good one, or have it mapped out.
JP
That filter might be too restrictive, worth checking before shelling out for a maf imo.
I did wonder whether that filter may have spunked all it's oil all over the maf....
JP
It looks like a dry foam filter to me?
Yeah as above, I was more thinking of it being too small.
Fair point, you are right. My ramair filters are the same. Dry.
I'll shut up.
JP
Those filters are pretty damn free flowing, i'd be surprised if it was being restrictive (other than sucking in hot air)
Cheers i'll try a new maf then. As for oil the brether has been removed from the inlet so theres no oil in the inlet (except turbo weeping)
Justin_306DTurbo
The maf is maxed out even on a stage1 remap.. Get your remapper to make it maffless or fit a bigger maf
Can't help with your problem but loving your engine bay. Inlove
I've been an advocate of the MAF delete for a while, I got shot down when I suggested it a good while ago on this forum. I've had some good success with MAF removal on these cars... just gotta watch the smoke!
JP
JP
You will never master the smoke mafless on them. The needed maps are too small. Fit the original sendor in a bigger housing instead. 3" is a good size. Smile
Ive got a 2.2 hdi maf. 80mm diameter and bigger perameters i belive, will have to ask pro_steve about that though he figured it all out.
I'm pretty sure Steve still misses a few limiters in his 'bigger MAF remaps' Smile
I think mine was the first he did, if you know more im sure he and i would love to know to help fine tune mine any more
Sure, send me the file, I'll take a look at it.
No offence slam wagon but that isn't very sporting sending someone else's map to another tuner. I would ask steve first tbh.
If anyone can sort it though, tb can!!
JP
I dont have a copy, only he has. I was just asking if he could share some knowlege as he seems to have more, especially than me.
And your right jp, as far as im concerned thats his property, his creation.
Yeah, that's the right way to look at it.
JP
May have to give the 2.2 hdi maf a try then Smile been bit busy painting atm
P.s cheers for the bay love lol
Justin_306DTurbo
Iirc the 2.2 maf does not give you much more measurable flow. Fit the original sensor in a 3" housing, like the 2.8 housing.
Will the map have to be changed for this?
Justin_306DTurbo
Yep. It will
JP
Even if i fit the 2.0 maf sensor in a 2.8 housing
Justin_306DTurbo
Yes, more flow at the same voltage.
Ok cheers Smile jammapic, what sort of magic could you work for me then on the setup im running?
Full straight through
Cg paddle clutch
Stock turbo on 21psi
Aircon delete
Ram air filter
Oil breather deleted from inlet
a custom maf (or maf delete if better)
2.25" piping to 3" intercooler
Currently in the ball park of 160bhp 290lbft on a whippy stage 2 map
Justin_306DTurbo
To be honest, without it being really smokey I think you are about where you want to be. Most I've seen from my maps on that setup is 301lbft and 174.9hp.
JP
Ok, cheers for the advice fella Smile
Justin_306DTurbo
Users browsing this thread: 19 Guest(s)
