Dpf Remove, Remap
Going to remove the Dpf on my 307, Should i Remove the filter then remap or the other way round?
Best person to speak to will be whoever is doing your map.
Remove it first so the map can be done to suit. If you have PP2k, you can change dpf filter from 'present' to not 'present' apparently. This was for a 207 but probably the same...
This is for the 16v hdi, its siemens Censored
[Image: g50p8y15.jpg]
I have one of thease after the turbo then to the Dpf
[Image: df17a70e.jpg&hash=3e2378c7ca205a3cb98939dbb19e3b09]
Id it worth removing both cats and the dpf?
Item 15 is the Dpf, 16 is the second cat, strange thing is i dont have the pressure drop thing, item 20
have i got thease parts correct?
Siemens isn't an issue, you just need to read and write it differently.
JP
Im in scotland, what would i use to read it? and send you the map?
BDM or similar
JP
