Bosch pump rebuild
Bosch pump rebuild
Anyone on here or knows of reliable person that can rebuild and replace the seals on these Bosch pumps?
Have a look at this guide - http://www.brick-yard.co.uk/forum/ve-inj...17456.html - and consider doing it yourself. Could learn a lot about how they work in the process! Big Grin
EDIT: My bad, linked the wrong URL. This one should be better. lol
theres afew of us on hear that can do it mate inc myself stick a wanted thread up im sure you will get some replies Smile
Lobbland. /Thread
I've just rebuild mine due to a leaking main shaft seal. Bought the kit from Darwen diesels which was aboot 16quid I think. The guide above is very good, some bits here too - www.eastment.net/index.htm
Plenty of rags and cleaning gubbins, plus a DECENT torx bit set/ socket set and measuring device ie digital caliper.
I want to buy another one to rebuild soon and 11mm. Then put my one on other halves car so I should be able to make use of a few guides on here
(04-09-2014, 08:16 PM)bashbarnard Wrote: I want to buy another one to rebuild soon and 11mm. Then put my one on other halves car so I should be able to make use of a few guides on here
Probs the best way, rushing it could = failure. I had a spare off my old 205 for parts just incase. TBH most of the seals are a certain shape/size/material so it's easy enough to identify the new'un against the old'un.
I am still tweaking the pump as I put it on an XUD11 engine, it ain't pissing WVO out so it's all good Smile
  Slack in bosch pump? dt_ 14 10,717 21-10-2020, 03:41 AM
Last Post: dt_
  Bosch pump help for newbie PugRy 2 4,219 05-01-2020, 09:09 PM
Last Post: jamie182
  Bosch pump fuel screw broken Forby 0 2,916 12-03-2019, 06:47 PM
Last Post: Forby
