Threads: 42
Car Model/Spec: Astor GTi6 P3
Thanks for the feedback Pebbles!
Idle is very lumpy (sounds almost like a rally car), but it's never died on me. On start up rev's to 2000, then settles at 900-1000.
Acceleration is as you wrote. I accelerate and say 2500 it's like I've dropped the clutch, no power nothing, then comes back kangaroo'in all over the place.
Very unpredictable when it happens, could do it at 2500, 1900, 2900 etc, but not over 4k - and it happens less and less until the cars warmed up.
I tend to just lift off and change gears when it happens.
Was going to take everything apart today, but yey to the rain!!
I am correct in thinking the picture is of the map?
Directly under the throttle-body as I can't find anything else that it might be.
Threads: 169
91
Sounds like the symptoms I had when my TPS went Pete Tong.
It soon developed into this:
Whip it off and see if its full of oil. If it is, stand up upside down overnight so the oil drains out. May help it a little. If not then it could need replacing.
81
If its over fueling massively and got an erstic idle its map sensor.
