Bosch pump leak
[Image: IMG_20140821_191015_zpsr9h4nsqw.jpg]
[Image: IMG_20140821_212855_zpsvspjjwdq.jpg]
[Image: IMG_20140821_212859_zps5e5y6o6t.jpg]
Right spotted a couple of marks on the road outside, quick smell test and it's veg/derv but can't seem to find out where it's leaking from. Hand at the bottom of the pump and it's very damp.
Pump off job to replace seals?
Anyone local who is up for it?
looks like a poss front main seal leaking and running down the back of the pump easy enough to do on the car but requires cambelt off but if ones died is stick all new seals in there tbh Smile
Typical!
So any pump wizards local :p
Christ more info needed to determine that one, it could just be an injector. I can only see a slight bit of oily residue on the block which is perfectly normal. The spot on the floor sure that wasnt oil? 'cos these motors leak like a bitch. Check the exact spot where its leaking from under the car.
Il report back tomorrow, definitely veg/derv tho. injectors are all A OK nothing leaking there, only spot I can see it is just below the pump as above.
Veg tends to swell rubber seals so you get more leaks. Mine was leaking from the top cover.
  Slack in bosch pump? dt_ 14 12,004 21-10-2020, 03:41 AM
Last Post: dt_
  Bosch pump help for newbie PugRy 2 4,513 05-01-2020, 09:09 PM
Last Post: jamie182
  Bosch pump fuel screw broken Forby 0 3,134 12-03-2019, 06:47 PM
Last Post: Forby
