09-03-2012, 01:10 PM
![[Image: sig2.png]](http://i1299.photobucket.com/albums/ag62/MattyyyP/sig/sig2.png)
Strange thing after rebuild (Video inside)
09-03-2012, 01:20 PM
Well, this is it, i changed one, as i run an inline filter, so that got replaced, there is one near the tank or something? Never really looked at that...
09-03-2012, 01:43 PM
Yup follow the lines out the tank
Should be cable tied up there near the os rear wheel
09-03-2012, 05:24 PM
4WayDiablo Wrote:Yup follow the lines out the tank I thought that was only on the petrols? I thought these just had the pump in the tank with a gauze on it then the filter in the engine bay.
09-03-2012, 05:52 PM
bigcheez2k3 Wrote:4WayDiablo Wrote:Yup follow the lines out the tank This man speak the truth? Though, I don't think there's a pump in the tank? But I have heard of a gauze before there. Hm.
09-03-2012, 07:00 PM
There's no other filter in the system, just the gauze in the tank and the filter on the engine (in your case - inline).
Check the tank pick ups under the back seat and your filter. If all is good, the hunt for an air leak begins!
09-03-2012, 07:01 PM
Will it do it when stationary when rev'd or just under load when driving?
09-03-2012, 07:46 PM
Sounds like part of fuel system is collapsing under vac, you still running primer grenade? try bypassing it, what kinda filter have you got?
| #DervMafia | ![]()
09-03-2012, 09:31 PM
I'll check in a min londondan86!
Darren - http://www.ebay.co.uk/itm/160684360836, fairly big compared to the standard one. I'll bypass it in a sec! Thanks for replys guys, really appreciate it.
09-03-2012, 09:36 PM
No dont bypass the filter, bypass the primer grenade,
Have you checked your tank pick up also, and what about air intake on tubo? its not made from flimsy silicon is it? I had an issue once where everytime it boosted up it sucked on itsself, starved the engine to hell, and wouldnt go back to normal until it returned to idle...could be that... | Dyno Power Runs & Steady State Facilities Available, Just Ask Anytime |
| #DervMafia | ![]()
09-03-2012, 10:01 PM
Yea, I meant that, maybe i put it wrong
![]() Just bypassed the grenade as you said, made no difference. Haven't checked tank pick up yet. Air intake on turbo...doesn't exist. Just open. This is so ghey sad times ^^Appreciate it!
12-03-2012, 10:55 PM
Ain't had much time recently, so haven't been able to investigate my fuelling problems, though this afternoon, filled up, went for another spin, and magically revved out till past 5k pretty fine.
No problems at all. But just gotta see how it goes. Though, not for a bit, as when I was "testing it", my exhaust fell off. o_O So had to drive back with it scraping along the floor, so gotta sort that lawl
13-03-2012, 03:42 PM
Matty Wrote:Ain't had much time recently, so haven't been able to investigate my fuelling problems, though this afternoon, filled up, went for another spin, and magically revved out till past 5k pretty fine. Could it be this guy made it? ![]() Either way at least its kind of sorted!
13-03-2012, 08:08 PM
trolololooollolololololololo
Well, meh, just sorting exhaust at the moment to go out and test to see if it still boosts and doesn't cut out. It cut out before at about 3.7k + and the td04 really starts going pretty nicely at 3.2k ish onwards, so was pretty ghey powerband I've been having to get used to. .5k powerband ftw lawlawlawlawl. Boosting around 35psi atm, as it just pins past the 30psi mark atm. Perhaps going to go for more, but meh, see what happens
13-03-2012, 09:24 PM
Cant believe no one else has said this but...
Nice jumper
TEAM TRACK CAR + An E60 530d M-Sport for the daily
14-03-2012, 12:22 AM
Yeah Matt, hate to say it...
WTF is that jumper?!
14-03-2012, 07:22 AM
Missus reckons he's gone and bought ron weasley's dress robes.
14-03-2012, 03:53 PM
rofl.....pahahaahahaha, i actually thought when i uploaded it, hmm...wonder if ill get any comments about that
![]() And look, i have ;D lawl. It's an awesome jumper.... ![]() Though, you can only see the arm part...should see the rest of it!!!! ; ) Right, just gonna put the exhaust back on now, after loosing/finding the springs for the exhaust etc again. (I lose everything as you can tell) Then get a vid again (I'll find a better suitable jumper rofl)....ermm, yea, just see what happens, ive got a boost leak, coals a bit on boost still, one of the nuts on the inlet stud isn't tightened up, realised it earlier. So that should be that one sorted. See what happens.... Matty xxxx *Note to self: Do NOT turn up to a meet in that jumper *
| cooling pressure issue(video inside) | bashbarnard | 4 | 3,149 |
02-09-2015, 02:44 PM Last Post: bashbarnard |
| screwed dturbo (Video inside!) | 4WayDiablo | 8 | 5,702 |
25-01-2012, 07:50 PM Last Post: Blaze tub tom |
