Wheel wobble annoyance :(
I have the same issue in the gti,
#32
Check the Pbushes...
#33
(15-07-2014, 05:49 PM)SRowell Wrote: Check the Pbushes...
lmao
#34
P bushes, front bushes, inner rods, out rod ends, drop links, top bearings....
All were new 10k or so ago or replaced recently...and they are all rock solid, no play anywhere.
But I have said that a few times already!!
So all taken apart, checked, replaced both driveshafts....
Still a vibration through the car above 65 Angry
Are your wheel bolts done up? Should be part of your pretrack check list just in case you dont know.
#37
Yup Smile and my p-bushes are in one piece too
Is there anything left that you haven't checked or changed now? Confused
#39
Have you checked for play in things with it NOT being jacked up? Sometimes the weight of hub etc can mask the play..
#40
Yup.
Only thing left is hubs I guess
I have swapped my front discs and pads due to discs being warped and ever since I've had a wobble. Only slight on gentle acceleration but at 65+ it's alot worse. Lime a drive shaft. Stripped the brakes and found the hub flange to have a bulge.. tried grinding g flat but still wobbles... New flange and bearings I guess Sad
  Wheel wobble/play mcglynn 11 6,099 04-10-2014, 08:52 PM
Last Post: mcglynn
  Acceleration wobble sherman306 7 4,891 07-08-2014, 01:35 PM
Last Post: Janne L
  steering wheel wobble dadaddy35 2 2,480 04-04-2014, 03:42 PM
Last Post: Toms306
