04-08-2014, 01:14 PM
KUGA ESTATE 2.0 TDCi 163 Titanium 5dr GVW 2250KG
Towing...B+E clarification...Advice
04-08-2014, 01:26 PM
Off down Exeter to pick my other 305 up at weekend, my dads coming with as he needs to pick something up from Swindon, gonna just stick l plates on for lolz
Don't worry sam, 305 doesn't weigh that much, specially after how much of its own rust the engine ate.
04-08-2014, 02:04 PM
OK,
So if these figures are for my car: Total (curb) weight (kg) 1385 Gross (max.) weight (kg) 1880 What is the max towing weight? Will it ever be greater than the Gross weight ? If not, that'd mean I have to get a trailer and car (noting it's kerb weight??) under 1880kg to be legal ? Should the max towing weight be stamped on the car anywhere ?
04-08-2014, 03:46 PM
Well I'm boned then
![]() So in the USA they can have a brake system that activates the hydraulic brakes of the car on a A frame using a linear actuator. I believe hydraulic brakes are not allowed on trailers in the UK - that correct? Unless it's an ex military landy or something like that. If with a A frame the car is considered to be a trailer, do all wheels have to be braked? Could you use the mechanical hand brake as a trailer brake ?
No they are, but it is controlled via an actuator on the brake pedal of the car being towed and has to be retrofitted. There is a company that does it near me, they have a small actuator or ram on the towing hitch, you slow down it compresses the hitch and applies the brakes. Same as the manual version on normal trailers
All the wheels need to be braked, (04-08-2014, 06:25 AM)Sambarker Wrote:(04-08-2014, 01:27 AM)toseland Wrote: To clarify the point.. VOSA suggests that once an A frame is attached to a vehicle, it becomes a trailer for all intents and purposes. and as such should conform to MAM/Weight regulations and braking regulations, ie it is not a car on a trailer. the towed car BECOMES the trailer itself and weighs however much is appropriate.. They have up to 6 years to prosecute mate, but you should have had to surrender the licence however.. I can't remember the specifics. Did he read you your rights at the side of the road? If so then you were charged there and then Given the choice between Niall and the sheep. I would choose the sheep!
/Toseland
05-08-2014, 08:03 PM
Read me rights at side of road but said he was referring me to the cps, I thought with motoring offences if they were going to procecute they had 14 days to issue you with a nip
06-08-2014, 10:38 AM
(05-08-2014, 08:13 AM)toseland Wrote: No they are, but it is controlled via an actuator on the brake pedal of the car being towed and has to be retrofitted. There is a company that does it near me, they have a small actuator or ram on the towing hitch, you slow down it compresses the hitch and applies the brakes. Same as the manual version on normal trailers Any info on that company please, save trying to find them via google ? TBH if that's legal, it's quite easy to brew something up. Forget electrical, can just be done with hydraulics as per the manual version and than I could use an A frame. Wire all the lights to active off the 13 pin connection too. Job done
http://www.sgmtowing.co.uk/
its all retrofitted to the car.. they actually modify the sub frame of the vehicle and add hitching points for hte A frame and no not so easy to "throw something together", the trailer needs to be verified and tested, all their work is Emarked and certified, it would be illegal without it as the trailer would be a new construction (05-08-2014, 08:03 PM)Sambarker Wrote: Read me rights at side of road but said he was referring me to the cps, I thought with motoring offences if they were going to procecute they had 14 days to issue you with a nip the CPS will decide whether or not to prosecute, as this isnt an offense that is dealt with by way of fixed penalty.. it would be the same if you said "i want to go to court" at the side of the road or refused the ticket for say.. speeding, or were caught speeding over what could be reasonably dealt with by way of a FPN Given the choice between Niall and the sheep. I would choose the sheep!
/Toseland
06-08-2014, 11:54 PM
(06-08-2014, 09:42 PM)toseland Wrote: http://www.sgmtowing.co.uk/ I disagree, if they wanted to prosecute, they would have had to send me a notice of intended prosecution within 14 days of the day I was pulled and read my rights
07-08-2014, 12:56 AM
(06-08-2014, 11:54 PM)Sambarker Wrote:(06-08-2014, 09:42 PM)toseland Wrote: http://www.sgmtowing.co.uk/ they can prosecute up to 6 years after the reported offence mate, 14 days is an absolute myth. Given the choice between Niall and the sheep. I would choose the sheep!
/Toseland
07-08-2014, 11:44 AM
(06-08-2014, 09:42 PM)toseland Wrote: its all retrofitted to the car.. they actually modify the sub frame of the vehicle and add hitching points for the A frameCheers for the link. That wouldn't work quite for me, I'd want different attachment points that a large lump of steel behind the bumper. Quote:and no not so easy to "throw something together", the trailer needs to be verified and tested, all their work is Emarked and certified, it would be illegal without it as the trailer would be a new construction Trailer? You mean the A frame part ? I'll go read the regs. I don't think there is a problem when it comes to trailers as far as making your own. For a A frame, does this mean it's treated differently? So the DIY approach is not allowed - we be surprised. Since hydro or electric control over the towed vehicle is allowed, it's fairly easy to build something to control it. Including the required vacuum pump.
07-08-2014, 12:19 PM
your trailer will be illegal if its not E-Marked,
/Toseland
07-08-2014, 01:08 PM
So I'll emark it and say it came from China.
11-08-2014, 12:55 AM
I'm still pretty confused with this. And would love a yes or no answer. Can I legally tow a trailer with a mini on it in my estate?
11-08-2014, 02:12 AM
we need to know the plated weight of the trailer, teh total weight of the mini, and the GVW of your estate mate.
/Toseland |
| What car; towing | ginge191 | 26 | 15,448 |
24-03-2017, 10:46 AM Last Post: Dum-Dum |
| Towing Question | Orta | 22 | 18,802 |
15-10-2016, 07:56 AM Last Post: Blaze Addict |
| Anyone got an A frame or towing dolly I can borrow please | Dum-Dum | 1 | 2,410 |
13-05-2016, 07:31 AM Last Post: toseland |
