Wheel wobble annoyance :(
#31
I have the same issue in the gti,
Check the Pbushes...
(15-07-2014, 05:49 PM)SRowell Wrote: Check the Pbushes...
lmao
P bushes, front bushes, inner rods, out rod ends, drop links, top bearings....
All were new 10k or so ago or replaced recently...and they are all rock solid, no play anywhere.
But I have said that a few times already!!
So all taken apart, checked, replaced both driveshafts....
Still a vibration through the car above 65 Angry
Are your wheel bolts done up? Should be part of your pretrack check list just in case you dont know.
Yup Smile and my p-bushes are in one piece too
Is there anything left that you haven't checked or changed now? Confused
Have you checked for play in things with it NOT being jacked up? Sometimes the weight of hub etc can mask the play..
Yup.
Only thing left is hubs I guess
I have swapped my front discs and pads due to discs being warped and ever since I've had a wobble. Only slight on gentle acceleration but at 65+ it's alot worse. Lime a drive shaft. Stripped the brakes and found the hub flange to have a bulge.. tried grinding g flat but still wobbles... New flange and bearings I guess Sad
  Wheel wobble/play mcglynn 11 5,785 04-10-2014, 08:52 PM
Last Post: mcglynn
  Acceleration wobble sherman306 7 4,693 07-08-2014, 01:35 PM
Last Post: Janne L
  steering wheel wobble dadaddy35 2 2,369 04-04-2014, 03:42 PM
Last Post: Toms306
