Is it deed?
Is it deed?
Went to Sheffield yesterday, anyone who's been will know is quite hilly especially from wigan (A57).
Gets there and at one point the car gets to 110degC. We dropped our daughter off at uni and went for summit to eat in a pub, at that point I could smell the engine was cooking. About 1.5hrs later we left after I topped the water up, it jumped reet back up to 110 after 10 mins so I pulled over and opened the bonnet to find summit behind the engine had split shatting it's coolant all over the place.
Question is, will the HG be fubared. I did refill the rad and turn engine over to see the water shoot out the rad about 6 inches.
You sure it's something behind the engine and not a cracked block?
Does sound like theres major issues either way tbh! Confused Havent you finished that 205 HDi yet? Big Grin
Not sure yet, will be going out too have a closer look soon. It still starts with a big cloud of grey smoke :?
205 is nearly finished but no MOT or tax or insurance so would cost a fair whack to get it on road.
Hmm, grey smoke could well be a bit of coal mixed with steam from water in the cylinders... Confused
Only sure fire way to test the HG will be a sniff test on the coolant tbh. Though obviously you need to find where it's leaking from first!
Shame about the 205 though.
Bummer, work is an 80 mile round trip too. Yeah tis a shame the 205 can't be used cos there's nowt wrong with it except the official documents lol Smile
Sounds like pressure could have made the hose split or come off the matrix. Sounds like it could be cooked get the hose sorted again and you could be lucky. Main thing is to find out the cause of it tho, brittle hoses/ bad matrix connection? Or just pure pressure from a blown HG. Get it plumbed up and sniff tested.
Had a look before and the coolant system pressurised instantly, think the HG has deffo failed Sad
replace it head skim job jobbed.
need to find the cause first.
It could easy be the bottom rad pipe that goes into the back of the engine.
Its possible you've done damage but i'd try and find the cause of the leak first and then see how she runs after that.
1. Fooby's Car
2. Fooby's Hire Car(s)
3. Fooby's Company Pool Car
Team Self Improvement
1. Learn to Car
How quick does it pressurize once you've sealed the pipe?
If the answer is fast, 100% head gasket. The loss of water will simply be it over-pressurising and splitting the hose before releasing the radiator cap from air being pushed in the water's place.
Matrix pipes have a tendency to get lose and sit on the exhaust mani!!
The old gal won't start anymore and pressurises the system instantly. I am almost certain the HG has gone now. It's a shame as I need a car asap so don't have time to fix it.
Why'd you let it get to 110 deg in the first place then??
