Threads: 371
29
Car Model/Spec: ford fiesta
I have a bosch pump but it has no adjustment on the top of it due to previous owner sort of smoothing it. Any one got a cap lying about and a stanard pin? Mines had an lda grind again not sure whats best thing to do remove or keep.
Threads: 47
14
Car Model/Spec: Ford cougar v6. Mk6 Transit
Given 20 thank(s) in 20 post(s)
I have an LDA top part if needed.
No pin though, just keep the ground one?
Threads: 591
54
I gota spare unground pin if wanted. Do a swap!
Threads: 371
29
08-07-2014, 06:37 PM
(This post was last modified: 30-07-2014, 05:36 AM by bashbarnard.)
(08-07-2014, 06:06 PM)Piggy Wrote: I gota spare unground pin if wanted. Do a swap!
Yeah y not. You got a cap to
Threads: 371
29
(08-07-2014, 05:14 PM)Danny Wideboy Wrote: I have an LDA top part if needed.
How much for top part?
Threads: 371
29
Anyone?
Threads: 591
54
Not got a cap. Just the pin
Threads: 371
29
Really need.the cap first for adjustment. If I cant get it adjusted correctly consider the ground pin your piggy for your standard one.
Threads: 136
2
Car Model/Spec: Phase 2 Dturbo
Given 1 thank(s) in 1 post(s)
11-07-2014, 05:35 PM
(This post was last modified: 11-07-2014, 05:36 PM by Ben.)
Surely even with stage 1 power on a standard turbo you will benefit from the ground pin?
Also just realised I have a spare pump, so we can swap caps and pins if you like, although I'm now goi.g away for weekend so will have to wait few days
Threads: 371
29
Probably then pin should be ok. Just not sure as havnt got it on car yet. Just need a cap to start with that has adjustment on.
Threads: 151
14
Car Model/Spec: 306 D-turbo
You going pugfest
Team Doesn't own a 306
Threads: 371
29
11-07-2014, 06:12 PM
(This post was last modified: 11-07-2014, 06:14 PM by bashbarnard.)
No im running tough mudder tomorrow. Will (pugmanxud) is though.
He might pick it up for me if I ask nicely. Also cap with the adjustment screw is the bit I need
Threads: 47
14
You can have it bud, just cover P+P.
Cheers.
Danny.
Threads: 252
7
Car Model/Spec: Xud sedan/Xud estate
Given 2 thank(s) in 2 post(s)
Sure its not the anti tamper cap still in tghere?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 371
29
i will check its not an anti tamper cap but im sure its not. danny wideboy ill cover the cost of postage for it for you. ill double check monday once im back in the garage that its defiantly not in there. then we will go from there
Threads: 136
2
If I'd known you were doing tough mudder I'd have taken it with me! Hope you got on alright, we all had a good laugh!
The adjustment screw is still in there but I think I cut it and screwed it in from the other side. Your welcome to try the other pump I've got if you'd rather have one without the lda grind and gov mod. I've not looked inside it though so no idea on condition
Threads: 371
29
Yeah was awesome we ran a 2.49 beat the 118 guys who it was there 16th run! Anyway I digress. Juat want adjustment to be fair. The ground lda might turn out to be ok.
Threads: 136
2
Well done thats a great time! Took us just over four hours but we had a group of 16 and could only go as fast as the slowest person!
Ok well let me know if you want to swap the caps and we'll sort out another meeting time
Threads: 371
29
Still need a standard lda cap if anyone wants to send one to me.
Threads: 115
26
Car Model/Spec: 306
I have a standard LDA cap but its been polished if you are interested inbox me
Threads: 371
29
have sent pm. would prefer a standard looking one though. loads of people on here are always stripping pumps someone must have one sitting about
Threads: 371
29
Still looking. People keep messeging me and not getting back.
Threads: 371
29
Someones got to have these out there. All you xud gurus and no spare parts. Just a pin and a cap. Standard nothing fancy.
Threads: 371
29
Also need the little plastic pivot.that lives on the throttle lever.
Threads: 203
Car Model/Spec: Peugeot 306
Threads: 371
29
How much posted? Also have you got the little plastic pivot arm
Threads: 203
the pivot arm off a lucas? for throttle cable
Threads: 371
29
30-07-2014, 07:02 PM
(This post was last modified: 30-07-2014, 07:04 PM by bashbarnard.)
Pivot arm that cones off throttle arm on bosch.
If not its not a problem. Ive done a bodge for now. How much for other bits?
Threads: 203
£5 posted got a couple off them plastic pivot arms will through them in
Threads: 371
29
The whole lot £5 posted? Thats awesome. You sir have a deal. Pm me your payment details.
