1.9 and 1.8 dturbo injectors
are the 1.9 and 1.8 injectors the same? thinking of getting mine refurbed if not.. or maybe having a spare set..
As far as I know they are Smile
Think the will be different pressure. Think 1.9 1s are 175 bar and 1.8 1s are something like 135bar. I maybe wrong though
I'm sure there the same. Pump will be differently setup. Lucas and Bosch ones are different tho
The 1.9's are higher pressure you say frosty? Could I see increased power with those?
(24-06-2014, 09:54 PM)LewisG306 Wrote: The 1.9's are higher pressure you say frosty? Could I see increased power with those?
Im not sure tbh, i guess it could make bit of a difference.
I could be completely wrong on the pressures any way
Lucas to Lucas I think they're the same.
Doubt you'll find a 205 DT with a VE pump.
The 1.7/1.8 that i mistook for a 1.9 had 135 Bar injectors and a Ve bosch pump that iirc was smaller in size and the shaft is also smaller
I replaced the pump with a 1.9 one when the old one got a leak and i broke it trying to fix the leak , whoopps ...
and i replaced the injectors with 175 Bar injectors
it felt noticable quicker
iv got the pump and old injectors if anyone wants some photos
Cherry red 205 XUD VNT - Project thread here http://306oc.co.uk/forum/showthread.php?tid=25522
