10-06-2014, 10:21 AM
Abs light, stop light and air bag faults help
10-06-2014, 02:03 PM
The airbag faults will be related to the dodgy pretensioner cables under the seat. Pm cully for some of his resistors or have a search for how to do it yourself.
ABS is the rear wheel sensor, replace with new
10-06-2014, 02:08 PM
I'm not sure that it the ABS sensor? Looks more like the ABS unit at fault unless I'm reading it wrong?
10-06-2014, 02:09 PM
Says right hand rear wheel? Sounds sensor related to me!! lol
10-06-2014, 02:11 PM
Right hand rear wheel inlet/outlet solenoid valve...the valves are in the unit that stop or allow fluid to give the brake pumping effect.
10-06-2014, 02:17 PM
I think that's unrelated http://www.206info.co.uk/Forums/viewtopic/t=50040.html
I would clear the codes, take it for a blast and rescan. Might be worth putting it on pp2k to be sure
10-06-2014, 02:22 PM
That is the problem of generic fault codes lol. PP would be the way to go tbh.
10-06-2014, 09:27 PM
When I searched that code on google it said it was a switch for the break pedal ?
10-06-2014, 09:37 PM
Search long enough it gives about 5 or 6 different things lol.
Get some proper diags on there and try again. |
| Engine light always on and had slight run-on | CaptainHair | 0 | 2,914 |
02-07-2020, 08:54 PM Last Post: CaptainHair |
| Engine management light came on ,, 306 hdi | barnesy213 | 10 | 9,882 |
25-05-2016, 07:08 PM Last Post: DeeTurbo |
| faults | pug306driver | 3 | 2,895 |
08-04-2016, 02:55 PM Last Post: pug306driver |
![[Image: F65527EF-DE80-47B5-84BC-C957A37498FF_zpszwhap6gz.jpg]](http://i811.photobucket.com/albums/zz35/maguire_led/F65527EF-DE80-47B5-84BC-C957A37498FF_zpszwhap6gz.jpg)
![[Image: 75CE9E59-2D3F-4A89-9F95-D8DE4B02254D_zpsigkzo2so.jpg]](http://i811.photobucket.com/albums/zz35/maguire_led/75CE9E59-2D3F-4A89-9F95-D8DE4B02254D_zpsigkzo2so.jpg)
![[Image: 11181578-A97C-4E42-9E0C-3B773421DFA3_zpssokidpvv.jpg]](http://i811.photobucket.com/albums/zz35/maguire_led/11181578-A97C-4E42-9E0C-3B773421DFA3_zpssokidpvv.jpg)
![[Image: 5FF1F18B-9A9A-4CCF-95A7-41C37397C5DA_zpswftkr2vj.jpg]](http://i811.photobucket.com/albums/zz35/maguire_led/5FF1F18B-9A9A-4CCF-95A7-41C37397C5DA_zpswftkr2vj.jpg)
