Threads: 87
48
tighten the wastegate on the turbo,did you replace the gaske when you changed the turbo?
Threads: 18
Car Model/Spec: 306 Dturbo s 1998
No didnt and il do that to waste gate
Threads: 87
48
i doubt it is wastegate to be honest, you've probably got a manifold boost leak, they're only like 6 quid, you should have changed it really.
Threads: 18
Yea wont be that but i could screw it more ? Its a t2
Threads: 87
48
(24-05-2014, 09:47 AM)pbell283 Wrote: Yea wont be that but i could screw it more ? Its a t2
try and voice your questions a bit better mate, you're hard to understand...
Threads: 18
If i screwed turbo more would it boost harder with the leak ?
Threads: 18
Il do that didnt relise how much boost u actually loose strugling to get 5 psi
Threads: 19
5
Car Model/Spec: Ph1 D-turbo(on going project)
you remember to reconnect the pipe going to intercooler from pump?
