Another airbag thread
I need to.know a coupke of things. For the life of me I cant find the thread that has the resistor I need to put in place of an airbag on the steering wheel. The second thing is location of the airbag ecu? Someone must know before I start pulling things apart looking for it
airbag ecu is located in front of the gearstick on the tunnel under the ashtray you will need to remove the lower dash gearstick suround and maybe the handbrake suround as its one unless the plastic welds are broken where its joined
the resistor is a 1.8ohm but please install a fuse in series with it to protect the airbag ecu
http://www.ebay.co.uk/itm/291141394578
Cheers cully! Over just orded one, was going to message you on Facebook to ask.
will be posted today Wink
(23-05-2014, 08:29 AM)cully Wrote: will be posted today Wink
Now that's service! :-)
Awesome thanks a lot. Can i.just remove airbag ecu all together?
(23-05-2014, 09:44 AM)tombarnard1989 Wrote: Awesome thanks a lot. Can i.just remove airbag ecu all together?
the airbag light will stay on all the time if you remove the plug for the airbag ecu
there is a small clip to remove in the loom plug to extinguish the lamp if you remove the ecu Wink
Where would said small plug be?
(24-05-2014, 03:47 AM)tombarnard1989 Wrote: Where would said small plug be?
its on the airbag Ecu plug be warned it may be at a different position on your plug
but it wont be connected to any of the orange wires Wink
[attachment=16434]
Ah I see I saw your thread with the 555 timer ive used that trick before. Ill get my wiring diagrams up on autodata and just double check it before I pull it out. Im probably putting phase one seats in too. So all wiring can be ditched. Next off abs.....
  yet another airbag light thread willJspears 0 1,542 17-09-2014, 01:12 PM
Last Post: willJspears
  Airbag light still on after removing and reinstalling airbag 306Puggy 28 22,685 26-03-2013, 07:17 PM
Last Post: 3gan
