21-05-2014, 10:15 PM
Just wondering if there is a difference between a phase 1 boss kit and a phase 2/3 boss kit?
Boss kit.
22-05-2014, 05:42 AM
They are different :-)
Ph1 has a nut securing the wheel/hub, ph2/3 uses a bolt. So the steering column is different.
Tinkerer of 306gti6 trackday racer, less stuff, more hard, more umpf, more stop.
22-05-2014, 02:50 PM
Ph1 wheels fit ph2/3 don't see why the boss wouldn't be the same could be wrong like lol
22-05-2014, 03:35 PM
Surely the boss will just have a splined hole? So you could sit it on the splines and put a bolt down through, or it would go over the threaded part and you could put a nut on it? So it should fit either??
22-05-2014, 03:59 PM
Bosses are different if you using an aftermarket wheel.
Sure you remember my small aftermarket wheel on the 5 door. Well I had to by a different boss as it would not fit the phase 2 3 door model.
22-05-2014, 10:42 PM
Well I'm using grants old omp copy. What's different about the boss? I looked on eBay for a difference but they have same part numbers.
23-05-2014, 06:35 AM
Can't remember now. But it does not fit hence why I bought a new one
