Threads: 202
58
Just trying to get the revs to work on the cabby after I've converted it to XUD, obviously the petrol dials run via the ECU. Anyone who's done a similar conversion know how to get them working? I thought about swapping the clocks, but I'm not convinced it'll work..
Threads: 129
11
Pretty sure Ruan said you need to swap the clocks. I still havnt got round to sorting mind yet.
Stage 2 XUD Sedan
Ill get my AD laptop out tomorrow and look it up for you mate if possible
Threads: 202
58
I'll swap the clocks and see if it fixes it..
Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
(22-05-2014, 07:19 PM)Jimbo Wrote: Ph2 dt clocks needed
Hmm i don't think so; i 'think' i took ph2 dt clocks and put them into the GTIDI and it didn't make a huge amount of difference...
Phaes 1 GTI 6 - Onyx Black
Threads: 122
9
Given 7 thank(s) in 7 post(s)
I know u need them when converting from hdi, which uses an ecu signal. Just gathered it would be the same
Threads: 202
58
Swapped them over and it all works, job jobbed!
