206 steering wheel removal
As above any clues 02plate thanks.
Remove battery
Remove airbag
Remove torx bolt from centre
Pull like f*ck.
Think that's it
(09-05-2014, 07:40 PM)Matt Wrote: Remove battery
Remove airbag
Pull like f*ck.
Think that's it
no no no! . . . leave the torx bolt in by a few threads, so when it comes out you don't get smashed in the face . .lol
Magic give it a go many thanks ,hoping something a miss with the transponder wire as car gone dead .into econ mode cooking thing ,its the last resort before its go to the scrapyard .
But where's the fun in that Matt? Tongue
Removing the airbag is a bit tricky. On each side behind, there is a hole with a spring clip behind it. You need to use a flat head screwdriver to push them in and the air bag will pop out. Need to give it a proper wiggle. Once off, disconnect both airbag connectors and the horn earth and then it's straight forward from there. Undo the BFO torx bolt but leave it in about 5 threads and smash it towards you. If you don't, it will come flying at you and smash you in the grill I promise lol
(09-05-2014, 08:03 PM)Matt Wrote: Buy where's the fun in that Matt? Tongue
sorry . . .i'm a real killjoy i know . .Big Grin
Give the wheel a smack towards the dash to loosen it a tad.
My 306 wheel needed a smack in both directions too loosen it off the splines
Its a pity I wasn't smacked in the face before I bought this heap shit,frigging pugs . up
(09-05-2014, 08:08 PM)molly Wrote: Its a pity I wasn't smacked in the face before I bought this heap shit,frigging pugs . up
woah . .thereeee hossi, don't tar us with the 206 brush thank you kindly . .Big Grin
Soz but I've got two pugs witch are dead :306 as well what needs alternator all un done but can't seem to get pass the p/steering bracket ,
What 306 is it? Sure we can help you out. There are a lot breaking atm
02 hdi meridian
  Steering wheel switch Niall 11 5,581 08-03-2015, 07:51 PM
