	Threads: 183
20
	Given 8 thank(s) in 8 post(s)
		Obviously my keyfob when I got the car was dead. so I bought 2x strips of 5 batteries for 69p, I know they wasnt going to last long but they probably lasted a day.
So now I got the car on the road I thought id treat it to some decent duracel batteries which cost me £4!
But guess what I put them in yesterday by the time I came to the car today they was dead! So it cannot jist be cheap batteries.
Anyone have any idea why this is happening and how I can sort it?
	Threads: 12
Car Model/Spec: '99 306 Meridian Diesel
		Does it need re-synching with the car ?
	Threads: 92
43
	Given 2 thank(s) in 2 post(s)
		New fob, thats a sign that its knackered
	Threads: 34
8
		Load the camera on your phone up, point the little led at your camera and see if you can see it light up when you push the button on the key, if not try sticking abit of paper etc on top of battery, might be loose connection
	Threads: 465
114
Car Model/Spec: Vauxhall
		you can take the switches apart if your carefull and have good eyes
they have a small metal spring disc in them that looses is springyness which makes the switch on all the time
	Threads: 183
20
		The paper tricked worked Thanks lads. Going to order New car tomorrow.
	Threads: 183
20
		So the paper trick didnt work. As the battery died again this morning. After playing I think the buttons may have stuck, can I replace them or is it a new fob?
	Threads: 6
1
	Given 1 thank(s) in 1 post(s)
		09-05-2014, 12:36 PM
(This post was last modified: 09-05-2014, 12:39 PM by DarkInferno.)
		I have replaced one of mine, however I think that if you can't answer the question of how/if you can change it yourself it might be new fob time.
Then again give it a go if you want... what is the worst that can happen? a broken fob.
also it might be an idea to scrub the pcb with isopropyl alcohol and an old toothbrush to clean any low impedance muck off.
another thing I found helped was I whetted the solder dots on the pcb that contact the battery with some fresh solder.
	Threads: 6
1
		You can program any IR fob in.
	Threads: 151
14
Car Model/Spec: 306 D-turbo
		I've got a couple if your wanting another pm me
Team Doesn't own a 306
	Threads: 183
20
		Wicked I'll give it a go tomorrow.
