26-10-2013, 07:56 PM
Checked out some stats...
a Golf R32 does 30-70 in 5.9...
happy days
happy days
30-60mph in 3rd times??
a Golf R32 does 30-70 in 5.9... happy days
01-11-2013, 04:44 PM
Thats petrol shite tho bud get that boost up
iv still not found my fault but impressed with my times even down on power roll on compo payout big blower remap, uprated clutch and 300 bhp once I get sorted and get to rs tuning haha
Why I'm putting this on here I have no idea
A gti shouldn't be made to do this in 3rd gear, it's not fair, but here it is! On my private runway of course!
02-11-2013, 03:40 PM
Are you supposed to do it in one gear (3rd in XUD case)?
02-11-2013, 04:41 PM
06-11-2013, 07:59 AM
What sort of times where people getting in there standard d turbos ?
21-04-2014, 01:14 AM
I just had a mate stop watch mine out of curiosity, timed 6.1 seconds, that running a lucas, which needs more fiddling, and t2 at 17 psi on a top mount cooler with a straight through zorst
21-04-2014, 06:49 AM
(21-04-2014, 01:14 AM)philpemberton94 Wrote: I just had a mate stop watch mine out of curiosity, timed 6.1 seconds, that running a lucas, which needs more fiddling, and t2 at 17 psi on a top mount cooler with a straight through zorst Im not saying you're lying but I would be very surprised if that time is accurate! Wishes for more power...
21-04-2014, 10:59 AM
Thats just what he timed it at, may be a bit more, so i will have another look later! it is a pokey little car though, spins up in second in the dry....
No smoke, No poke!
21-04-2014, 01:06 PM
To be brutal, 17psi is only just above stock psi, and with a lucas, I would think its more like 9.1seconds unless you have stripped it bare?!
21-04-2014, 01:07 PM
Be lucky if its under 10 seconds tbh...
Peugeot 206 GTI HDI
Volvo V50 2.0d Volvo XC90 D5
21-04-2014, 01:33 PM
No not stripped out! But like i said thats what he timed it at, so ill try again with someone else timing it haha, its definitely not 10 seconds though!
21-04-2014, 05:24 PM
I dont think anyone has cracked 130bhp on a lucas and those who were close were almost certainly running more psi. So as much as you think its "pokey" drive one with a modded bosch and a bigger turbo you'll never want a standard turbo again
21-04-2014, 05:42 PM
i had my lucas tuned to 20psi, never timed a 30 to 70 run, but certainley wasnt under 8 - 9 seconds, well downhill maybe
22-04-2014, 09:12 PM
http://youtu.be/L95cyUVDABA
Bosch pump screwed, Lda washer removed and turned to steeper side, Ko3 turbo standard Tmic HDI D'Turbo Daily Driver ---- XUD D'Turbo Project
22-04-2014, 09:19 PM
I make that 8seconds. not bad really....esp as its arse is draggin
22-04-2014, 09:35 PM
(22-04-2014, 09:19 PM)Piggy Wrote: I make that 8seconds. not bad really....esp as its arse is draggin Yeah stopwatched it a few times its around 7.5 to 8. Arse is draggin a bit alryt, in the middle of rebuilding another axle, when that goes on ill rise it up 10-20mm. ![]() When i get my 2.5 inch straight pipe on would you say that time will drop a bit? HDI D'Turbo Daily Driver ---- XUD D'Turbo Project
22-04-2014, 09:39 PM
not really, it should spool a little more mind...a little ko3 aint really going to see much improvement...2.5inch is crying for a bigger blower
22-04-2014, 10:00 PM
Ah at least it'l sound good with it anyway
HDI D'Turbo Daily Driver ---- XUD D'Turbo Project |
| 50-80 acceleration times. | daveylennon93 | 17 | 10,787 |
17-07-2014, 08:59 AM Last Post: kelvsere |
| Sad Times Are Sad | c.gerrard | 15 | 8,101 |
30-11-2013, 08:51 AM Last Post: darrenjlobb |
| probably been asked a million times before... | LewisG306 | 3 | 3,199 |
04-10-2013, 03:01 PM Last Post: Piggy |
