Threads: 151
14
Car Model/Spec: 306 D-turbo
Putting a 1.9 in my 309
Is there any pipes that need changing or anything
Basically do I need anything off the donor car or do I need just the engine?
Team Doesn't own a 306
Threads: 132
What are you doing about power steering?
Threads: 151
14
Not sure saxo electric pump I recon
Threads: 87
48
might have to butcher matrix pipes at a guess? . .
I would grab all the pipes you can, then you can cut n shut n join and make what you need. Chuck the rest when its in.
Good plan by the way!
Threads: 151
14
Yea suppose pipes is the only difference really?
Threads: 132
Matrix pipes shouldn't be that different really, surely all the 1.8 stuff can just bolt to the 1.9 block. Oil heat exchanger will need plumbing in unless you don't use it and use an oil cooler.
Threads: 371
29
Car Model/Spec: ford fiesta
Also use the 18 gearbox saves buggering about with driveshaft issues. Either that or use the 1.9 box and put the 1.8 diff in it
Threads: 151
14
I'll use 1.8 box to save effort lol
Threads: 92
Car Model/Spec: Subaru 20.d, GTi 6, 205 xs
Danny look at my 205 build thread its got a walkthrough for the gearbox
Vehicle repair and servicing in the midlands pm for detailsĀ
Current cars
Subaru Impreza 2.0d - Daily
Threads: 92
Not really just swap all the sensors over so you can use the original loom, more than likely need the 309 downpipe, and thats it really its pretty simple tbh its just the little niggly jobs that take for ever
Current cars
