13-04-2014, 05:33 PM
White smoke often indicates timing too retarded. It's only partially combusting causing the white smoke.
Help please.... Before i burn it.
13-04-2014, 09:04 PM
thought so, is there any trick to getting these things timed properly, they seem to just be a pig
19-04-2014, 02:42 AM
Its alive and running well
![]() now it seems clutch is slippping... peugeot life...
19-04-2014, 06:36 PM
Good stuff sweeney, glad you got it sorted!
Put a td04 on it, itl move the torque up the rev range and save your clutch
20-04-2014, 11:29 AM
nah cant be arsed with that, its a daily hack so i'll just go easy until i can afford new one, its not too bad just when you hit it hard, on 130k so probably on orginal clutch
I put on a k03 turbo while i had turbo off, like the quick spool
20-04-2014, 01:43 PM
My car is on 190k on the original clutch. It started to slip when I had the gt15, td04 solved that and still got 170bhp
21-04-2014, 11:07 PM
interesting alright, must be the lower end torque, something to look into at some stage..
