13-04-2014, 11:54 PM
Looking for something for 20mm spacers, what length size and thread etc do you guys normally go for?
![[Image: 20A1806D-891D-40FB-BD52-AD519177A607-734...391753.jpg]](http://i35.photobucket.com/albums/d196/mattbush/20A1806D-891D-40FB-BD52-AD519177A607-7340-0000058F46391753.jpg)
Stud and nut conversion
14-04-2014, 05:29 AM
With 15mm I'm using 70mm, so if I was you if go for 80mm.
14-04-2014, 05:54 AM
As Kent said. 80mm. M12x1.25
You know where the button is
![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
14-04-2014, 06:33 AM
Anyone ever had problems with stud conversions? Been considering these
Justin_306DTurbo
306 Ph1 Dturbo Sedan 306 Ph1 Dturbo Estate (VNT) Partner Ph1 (XUD Swap) 306 HDI Stage 3 Estate (RIP)
14-04-2014, 06:37 AM
Providing you do it right, there should be no issues at all.
IIRC, if you want to go on track, you will need open ended turner nuts. The track authority need to see the thread of the stud ![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
14-04-2014, 06:55 AM
I have had them on my car for a few years now. No issues. I did loctite mine into the hub though also.
I would measure the depth of the hub and then buy studs that are long enough to go all the way through the hub.
14-04-2014, 12:32 PM
(14-04-2014, 05:54 AM)Grant Wrote: As Kent said. 80mm. M12x1.25 Yes grant that's a great point. I never get rep! (14-04-2014, 06:55 AM)Pompey306mark Wrote: I have had them on my car for a few years now. No issues. I did loctite mine into the hub though also. Yeah mine have about 15mm going into the hub so no problem there. But I also loctite them. Ive been using them for a few years now without any issues.
14-04-2014, 12:40 PM
Don't buy grayston it's!
The threads strip far too easily !!
10-05-2014, 08:12 PM
Well, 80mm is f*cking massive, once the wheel and spacer is on, it sticks out the end of the nut by 20mm so 60mm would have been fine
Christ knows where 80mm came from? ![]() TEAM CONROD SHITTING RALLYE!
10-05-2014, 09:16 PM
Well I had 80mm and had to cut 10mm off with my 15mm spacers.
10-05-2014, 10:13 PM
As I said thicker wheels. Centre of most wheels like cyclones or aftermarket stuff have deep faces.
Your steelies don't.
10-05-2014, 11:13 PM
Didn't realise you was using steels. Then mark is correct, probably 60mm would do. You could cut yours down or ask company if they'll change out of Good will.
11-05-2014, 01:49 AM
They won't change as get are a being a lady garden lol. Time to get the angle grinder out
![]() TEAM CONROD SHITTING RALLYE! |
Stud conversion sizes.. | Wor Jimmy | 5 | 4,446 |
10-01-2014, 11:13 PM Last Post: Wor Jimmy |
