Wanted: Standard 306 cdplayer headunit
Does anyone have a standard radio to put in a 306, i want to change mine due to it not working but i like the standard headunit, would also help if had pin number
I've got one I'll have to check for the number..
reading up on here, all is needed it the serial number sticker to be on it still
Anyone?
I have one, how do I get then out? Or is it just like normal hu?
Depending on which headunit it is, either it will have 2 holes each side to stick nails in and pull out, or if you look along the bottom edge, ill just see 2 cut outs about 15-20 mm long, you need to get a couple of small thin bits of steel in there to pop the bottom clips.
Cheers will see later
cool thanks
Im also after one of these for the rallye if anyone has one cheaps (obviously once Matt has one)
i think i have two or three of these, will check if they have codes Smile
Ok then thanks chaps
Codes are easy to work out from the serial number
There's one on back of my dad's 6 woo see what he doing he it as well. Not had chance to get other out of the 6 yet.
Ok mate
anyone?
I've got a standard CD changer if that's of any help Smile
not really! i just need a replacement headunit!
but thanks
  Wanted: Cheap P3 Standard Headunit C2K 17 7,116 01-02-2014, 08:29 PM
Last Post: Nadine
