Drum brakes
Birds mot is coming up on her 206 and she leaves it till now to tell me about a few problems!
Main problem is brakes. She put the handbrake on and got out and so did I. As I did I lent on the b pillar and pushed the car back. After reminding her to put the handbrake on I realised she had. I then told her to MTFU and put it on properly but to put it on all the way, the handbrake is almost vertical!
Next thing is when I took it for a burn (how disappointing is it that the 1.4s only go to 5.5k?) is one of the rear drums is sticking. Now I've never had a car with drums that I've had to do brake work on so I'm a bit useless! What could be causing the sticking? Is it just going to be a case of taking them apart and freeing everything up or will it be a case of a new slave cylinder?
Cheers guys
5.5k?
Tart, 6200...
Could be slave cylinder, probably more likely to be a sticking self adjuster, hence the handbrake coming all the way up the ratchet. Well adjust drums should engage by 2 clicks and hold rock solid with 4-5.
Rippthrough Wrote:5.5k?
Tart, 6200...
Ah will have a play with it at the weekend.
I must say, them 1.4s don't go too bad for what they are! Nice and easy to work on too
  Adjusted drum brakes, now they're stuck - help! heyitsroth 5 3,479 28-05-2016, 07:16 PM
Last Post: heyitsroth
  Gti6 brakes on front, drum on rear MarkHam 5 3,935 13-04-2014, 10:54 PM
Last Post: Mattcheese31
  ph2 drum on to ph3 estate puglove 12 6,868 11-05-2013, 06:05 PM
Last Post: Toms306
