Xud with a little poke
Hello ,
i have a citroen bx , started work on it a while ago , it`s easyer to check the history here ... http://www.nosmokenopoke.com/forum/showt...troen-Bx-D
Now the car has a new setup with new parts , new camshaft , new clutch , new injectors , new engine(with stock parts),vibratechnix engine mounts and so on , the car i am making for drag racing only , hope it will be in lower 12 maybe high 11 sec only diesel and turbo . Then maybe lower ... depending on the performance of the gearbox Smile) i cracked a lot with less power ...
In progress is a peugeot 406 as you may know it with nitro - i will keep track of it here after is done (after 1 gearbox and 3 driveshafts we decided to put bigger turbo and a LSD )
And another citroen bx with aircon full street with 1.9 td and over 200hp , still buing parts for it .
All parts are made in our shop , or in a friends shop .
[attachment=14975]
[attachment=14976]
[attachment=14977]
[attachment=14978]
[attachment=14979]
[attachment=14980]
[attachment=14981]
[attachment=14982]
My bx was 233bhp , unfortunetly injectors were the problem a few years ago , now i cracked the problem and put nozzle wich can flow 100hp per piece . Hope the gt35 turbo does the job of making the most powerfull xud . If i can find a way to make the conrods i am sure i can go much higher ...
[attachment=14974]
Just wow.
have been doing a lot of looking around at folks builds on here. What has surprised me is that not many have changed their injectors. Just lots of pump mods.
So you're welding that intake piece onto the front of an existing intake manifold that will be cut down ??
Great projects! Going for some serious power there Smile
Seriously impressive power for an XUD!
Team Cyril
Great projects....MORE PICS!!!!
The 2.1 wont need rods changing Wink
Top work, what is the clutch setup?
That's a rapid old BX you have there! It'll be interesting to see this evolve even more Big Grin
that manifold. so much porn. looks to be an awesome build Big Grin
You were pushing 233hp on a stock engine?
Thanks , the engine is still using stock parts , but with some work done so it will cope with the power . The clutch is a twin disc setup with kevlar 230 mm . It is first one made and i am testing it until we will make these for the street cars . And the intake will use a bit of stock part , as the stock 2.1 td is from 2 pieces .
I have a lot of work and it is hard to find time to make photos , but i promise i will make more as soon as the work goes on , also i will post from the 406 .
Hope the results will be as high as i think ! cheers
300 bhp is the mark to beat. Big Grin
