Heater blower fault
Heater blower fault
They where working fine then tried it the next day it's didn't work iv checked the connection for the dial and the fuse
checked the connection on the blower end? sometimes can become loose/corroded/broken worth double checking. if not its probably a dodgy blower motor and will need replacing. which is an easy enough job Smile just make sure when buying a replacement that you get the right one, ac and non ac are different
(04-04-2014, 01:35 AM)Matt Wrote: checked the connection on the blower end? sometimes can become loose/corroded/broken worth double checking. if not its probably a dodgy blower motor and will need replacing. which is an easy enough job Smile just make sure when buying a replacement that you get the right one, ac and non ac are different
we only checked the fuse and heater control side of the wiring connections well have to have a look at the motorside tomorrow because we ran out of time today.
NO SMOKE NO POKEBig Grin
  Heater blower issues Dturbo john 5 5,325 13-03-2018, 01:53 PM
Last Post: Toms306
  Heater Blower Issues MY95 7 7,026 06-03-2018, 11:22 AM
Last Post: Magenta Sunset
  Heater blower problem Pingaz 7 4,976 04-06-2016, 01:19 PM
Last Post: Pingaz
