Threads: 141
35
While the beam is off my gti6 I figured now would be a good time to fit some new mounts.
The square one is as simple as it gets to replace, however the front mount (with the two bolts) is causing me a bit of bother.
Basically, how do you get the bottom bolt out far enough to get the mount off? As it only comes out a couple of inches before it is obstructed by the trailing arm.
Am I missing a trick here, as far as I can see, the only way to get the bolt out far enough is to pull the arm out?
Threads: 169
91
You have to force the trailing arm down and drift it out with another, longer bolt. It is a ball ache, but do-able
Threads: 465
114
Car Model/Spec: Vauxhall
Threads: 141
35
Looks like it's easier when the beam is on the car from the way you did it cully, I think I'll do the same as there's something to push against then rather than rolling around on the floor.
Cheers for the guidance fellas, rep accordingly
Threads: 169
91
Still waiting on mine
Threads: 169
91
Thats better
Threads: 110
20
Long punch and a hammer had never let me down
Threads: 96
7
Car Model/Spec: 306 tractor
That's a nice thread cully as I may need to do mine soon, need to check at zachs next weekend as it's an mot failure
Threads: 141
35
Best on or off the car Frosty?
Threads: 164
25
Car Model/Spec: Gti6
I found it easy enough getting mine out off the car mate don't really remember how I did it without looking though lol
/unhelpful post
Threads: 96
7
Got any spare mounts just incase Zach?
Threads: 465
114
il have your fobared mounts
Threads: 96
7
(27-03-2014, 08:28 PM)cully Wrote: il have your fobared mounts
So what is cully building..?
Threads: 465
114
Nothing
[attachment=14709]
Threads: 110
20
(27-03-2014, 07:27 AM)ozonehostile Wrote: Best on or off the car Frosty?
Ive done them both on and off the car before. Just need to let it know whos the boss
Threads: 141
35
Haha, I'll have another crack at them again tonight
Threads: 96
7
Sounds like fun mate
Threads: 25
Car Model/Spec: Dturbo
(27-03-2014, 10:37 PM)cully Wrote: Nothing
I was thinking about doing this myself, when mine eventually fail.
How harsh are they?
Threads: 465
114
(28-03-2014, 03:12 PM)anto Wrote: (27-03-2014, 10:37 PM)cully Wrote: Nothing
How harsh are they?
not fitted them yet
Threads: 96
7
What are they for cully?
Threads: 465
114
(28-03-2014, 05:07 PM)devils_fuel Wrote: (27-03-2014, 10:37 PM)cully Wrote: Nothing
maybe the six if they fit
Threads: 96
7
Homemade solid mounts?
Threads: 465
114
(28-03-2014, 07:13 PM)devils_fuel Wrote: Homemade solid mounts?
Maybe
[attachment=14712]
Threads: 96
7
28-03-2014, 10:22 PM
(This post was last modified: 28-03-2014, 10:22 PM by devils_fuel.)
Very nice
Threads: 25
Any bracing inside them cully?
Threads: 465
114
(28-03-2014, 10:23 PM)anto Wrote: Any bracing inside them cully?
no there is no bracing inside, but once i clean them up and paint them, i will probably fill the void with silicon or somthing to stop water getting in and rusting them
