Threads: 15
Car Model/Spec: gti 6
I have seen on here some people remove the spring from the clutch pedal.
could anybody tell me the advantage of doing this and should i remove mine. (gti 6).
many thanks.
Threads: 10
2
When I removed mine it got rid of the stiffness right at the bottom of the travel as that is when you start to compress the stuuuuupidly stiff spring.
Threads: 581
195
There was a recall to remove them shortly after the PH3 was released. It was causing some clutches to slip and wear prematurely. Sack it off. Also makes the clutch feel much nicer.
Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
Is there a guide or a few tips in removing them? Need to rid mine
Phaes 1 GTI 6 - Onyx Black
Threads: 581
195
lol its literally just two ball joints. Use a flat head to pop the clips out of the ball joint cups then pull it off (giggidy)
