Audio promblems
Audio promblems
Ok im having a massive problem with my cars audio atm. Iv just installed my new head unit into her and changed the front speakers to sony so im running sonys all round with a JBL sub, was working perfect till suddenly all vocal audio started to skip evn on the radio then suddenly cut out so i only had bass running thgrough the sub?
secondly my front right speaker and my rear left speaker wont work but iv swapped all the speakers around now and they all work 100% apart from when they are in the front right and rear left :S
any ideas people?
I reckon the front right and rear left problems just down to some wires coming loose. Could either be loose wires near the speakers, or lose wires at the plug into the back of the headunit. As youve just swapped your headunit then id guess youve knocked the cables for the rear left and front right speaker out when you were changing the plugs around.
Pull it out and check them all. I think the speaker wires are
- green
- green with a black stripe
- purple
- purple with a black stripe
- white
- white with a black stripe
- grey
- grey with a white stripe
hmm that seems abit of a mission todo all that as i hate wiring all together! will give it ago though.
Mowle5677 Wrote:hmm that seems abit of a mission todo all that as i hate wiring all together! will give it ago though.
Well there are 2 choices really Tongue
1......do the above and try to fix it........
2......do none of the above and put up with it as it is........
So stop moaning or get on with it Big Grin
Team Orange Engine Bay
haha i will do when i can finally be arsed to get out of bed lol
Mowle5677 Wrote:haha i will do when i can finally be arsed to get out of bed lol
lol You lazy bugger! I have been at work since 7:30............
well after my little 3 week holiday ends ill be working hard haha.
just tried to fix it and still no luck Sad
Go try harder.
ill take a hammer to the lot soon! and my blower motor has broke again. leave work and come helpo me dan Wink
Sony stereo? It's f*cked! Haha
If I'm understanding you right, it does sound like your head units given up. Can you borrow a mates to test?
grab a old speaker that works and test all the speaker wires are giving sound seperatly..if they do its just a wireing prob as iv had it in the past that the fault only occurs with all speakers connected but not when singley. try it
raymond76 Wrote:grab a old speaker that works and test all the speaker wires are giving sound seperatly..if they do its just a wireing prob as iv had it in the past that the fault only occurs with all speakers connected but not when singley. try it
That's a HU problem then mate. All the speaker wires go directly to the HU singly.
Just spent an hour trying to fix this. Looks like is loose connections at the speaker end/door looms. Semi fixed it by removing the 2 front speakers, then the rear ones worked. Typical 306!
clearly didnt do a good enough job... did you dan ... :p
/trololololol
1. Fooby's Car
2. Fooby's Hire Car(s)
3. Fooby's Company Pool Car
Team Self Improvement
1. Learn to Car
Dan! Wrote:Just spent an hour trying to fix this. Looks like is loose connections at the speaker end/door looms. Semi fixed it by removing the 2 front speakers, then the rear ones worked. Typical 306!
one rear speaker haha. tomorrows job Wink
  Components/volume/audio things Tom 5 3,622 16-01-2013, 04:28 PM
Last Post: Tom
  Audio Budget - What to get?? ginge191 188 100,890 13-05-2012, 11:02 AM
Last Post: ginge191
  audio stalk and new head unit aaron_one 6 3,839 09-05-2012, 09:23 AM
Last Post: aaron_one
