Threads: 195
6
Car Model/Spec: 2000 Xs 1.8 16v
04-03-2014, 10:30 PM
(This post was last modified: 05-03-2014, 11:34 PM by underground375.)
So Some of you know the cherry dt's engine locked up shortly after the owner rebuilt it. Well ill let the pictures do the talking. Please note this car never go driven on the road after the rebuild!
Lets see who lists all the problems
[attachment=14053]
[attachment=14054]
[attachment=14055]
[attachment=14056]
[attachment=14057]
[attachment=14058]
[attachment=14059]
I do have to say he did buy all the rebuild kit with a nice metal head gasket! But are these decomp pistons? Im lead to believe so?
Taking the bottom end apart tomorrow to see if they are hdi rods and why she sized solid.
Threads: 226
24
Car Model/Spec: A3 TDi
The indentations in the pistons do look a bit shallow so possibly. You say the engine has locked up? Whys everything covered in oil?
Aren't decomp pistons just normal ones with the top shaved off a bit? If so, they do look like that lol!
As for seizing, gotta be lack of oil surely? Lack of lubricant and overheating of something, big end shells or maybe pistons I guess....maybe they forgot to refit the oil squirters?
Threads: 226
24
Actually looking again, cylinder one (cambelt end) looks higher than cylinder 4. And also the bores are like brown. And the valves and the head look like they're caked in oil :/
Wow that looks like a good job done!
Threads: 195
6
Well looking at it in person theres oil dripping down the side of the bottom end. water inside the chambers. No way the metal gasket was doing its job! The oil on the pistons and valves I don't no??? The head wasn't cleaned nor the bottom end, So he rebuilt it on a dirty block !
Threads: 100
Threads: 195
6
Not naming people but I got it off a chap on Fb, Engine started, few rev's then cut out sized solid! will be taking the sump off tomorrow.
Threads: 100
Hope my engine is not like this then when I start it.
Threads: 34
8
How long was it stood for the waterways to be THAT corroded :/
Threads: 195
6
I had it for around 3 weeks before I took it apart, Before then not to long.
Threads: 465
114
Car Model/Spec: Vauxhall
Head gasket up side down?
(04-03-2014, 11:01 PM)underground375 Wrote: Well looking at it in person theres oil dripping down the side of the bottom end. water inside the chambers. No way the metal gasket was doing its job! The oil on the pistons and valves I don't no??? The head wasn't cleaned nor the bottom end, So he rebuilt it on a dirty block !
That's a pretty major fail tbh...how long would it take to clean it up ffs!
And now you mention it, the headgasket does have carbon/soot between the cylinders so looks like it was blowing between them, and obviously where the water got in too. So I'm guessing its bent a rod if there was water in there?
Also, check that the block/head aren't warped at all if you're rebuilding it, as I wouldn't be surprised tbh. If he didn't clean the block I guess he didn't skim the head either?
^^^my thoughts exactly. Be curious to see what crank is like
Threads: 195
6
No head skim not clean up what so ever. Oil pissing out down the side of the block and everything. I will be taking the bottom end apart tonight, will upload my discoveries
Threads: 55
17
Car Model/Spec: 406 V6
Looks like it's been running with no/next to no antifreeze tbh.
Threads: 195
6
Managed to get the block turning by using a breaker bar, This is how the pistons sit at tdc.
[attachment=14065]
[attachment=14066]
Threads: 195
6
Defo decomp taking them out tonight with the rods.
Threads: 226
24
Can see lines on them from where they were in the lathe.
Threads: 31
Car Model/Spec: tu5 bitza/cherry dt
Come on don't keep us waiting what happened to it
Threads: 96
7
Car Model/Spec: 306 tractor
...a mess?
Threads: 195
6
05-03-2014, 11:31 PM
(This post was last modified: 05-03-2014, 11:33 PM by underground375.)
So it all looks normal when I took the sump off.
[attachment=14093]
[attachment=14092]
Untill I took the shells out, here's what happened.
[attachment=14094]
Three shells looked like this, by the looks of it the chap was working in a very dirty space as the shells was covered in dirt and grit. coursing this damage.
but then I got to the 4th shell. (Fly wheel side) To be greated with a loose bolt on the shell casing :O
[attachment=14095]
[attachment=14097]
[attachment=14096]
What a Tool!!!
A piss poor head change and a loose bolts! Even when I was taking the sump off there was a bolt missing and 3 bolts where loose! Just say away from engines pal.
Threads: 371
29
Car Model/Spec: ford fiesta
Aint seen shells like that in a while. Hows the crank?
Threads: 195
6
LAst picture shows the damage to the crank, Big ends no good so its on the scrap pile =\
Threads: 96
7
Scrap or an XUD coffee table
Threads: 31
At least you have a crank there if you fancy making a scrap dog
Threads: 195
6
(06-03-2014, 11:36 AM)306Dan Wrote: At least you have a crank there if you fancy making a scrap dog
I like the idea of that lol
(05-03-2014, 11:31 PM)underground375 Wrote: A piss poor head change and a loose bolts! Even when I was taking the sump off there was a bolt missing and 3 bolts where loose! Just say away from engines pal.
This is the reason I hate buying 2nd hand cars without history, people like that have been trying to fix them! Did you buy the whole car or just the engine? If its the car I'd be checking everything else as well lol.
