04-03-2014, 12:53 PM
My radio is asking for the code I've got the code but I'm not sure how you get letters on the radio it's the original CD player. The code is 2 numbers and 2 letters.
CD player
That's not the code for the radio, that is the code for the ECU for when you what to add more keys to the immobiliser .
The code for the radio should be four numbers. Below is how to work out the code. Quote:This method worked for me! Taken from the 6 forum.
06-03-2014, 06:10 PM
NO luck with that method pal
06-03-2014, 06:13 PM
That doesn't work with the ph3 Clarion unit unfortunately Dee. I've tried it on a few and had no luck.
If you look through the handbook and servicebook you'll probably find the code though, should be 4 numbers as above.
06-03-2014, 06:39 PM
That's strange it's worked on all the ones I've tried it on.
Are you guys using the numbers off the right label?
Hmm, I think so....
![]() Mine started CL04 etc though iirc, and sure Ive read other people had the same problem with that particular radio. Is/were yours a tape player with the separate 6 CD changer?
06-03-2014, 07:37 PM
![]() Did you use the top set of numbers on this label?
No idea, honestly can't remember now. Sure it started CL instead of just C* though.
(06-03-2014, 07:01 PM)Toms306 Wrote: Is/were yours a tape player with the separate 6 CD changer? Sorry just seen that bit. Mine is a CD player PU-2294A (06-03-2014, 07:42 PM)Toms306 Wrote: No idea, honestly can't remember now. Sure it started CL instead of just C* though. The CL number is the serial number and won't work. Some of the label do come off and get lost. I've seen a few on ebay like that. (06-03-2014, 07:50 PM)DeeTurbo Wrote:(06-03-2014, 07:01 PM)Toms306 Wrote: Is/were yours a tape player with the separate 6 CD changer? Hmm, pretty sure that's the same code as mine were, single CD slot ph3 clarion.... Maybe I was using the wrong number then lol! Fair enough, may bad.
15-03-2014, 05:59 PM
Got the radio going, thanks guys, only problem Ive found is it will only play cd's when the ignition is off, once I start up it wont play
| Relocating cd player | Shea | 10 | 5,674 |
20-02-2013, 03:29 AM Last Post: Shea |
