I've just been ignoring this problem for ages, but it's getting unbearable now :roll:
I'm assuming it's the check straps, unless there's some magical quick fix for it, in which case has anyone got a part number and price? All 4 doors are pretty noisy, but the passenger side rear is particularly bad, so will just replace that one if they cost a fortune.
Is it a hard job? I had a little search around and seems like it's door-card off and some jiggery pokery to get them in and out.
Cheers chaps.
Try some spray grease first, that could quiet them up a bit, is it a clunking sound? As you might be able to get away with new pins which are only about a quid i think, last thing you want to replace are the actual check straps as they were £15 last time i bought some
If its clunking that means there's play in it, which a new pin might fix, but if there's been play for a while, its probably worn the hole and a new pin wouldnt fit, which would mean new strap
New bolts? Well done tom for confusing things... Just read my previous post kez lol
I've remembered the difference now, on ph3s they have a pin which is colour coded and flat on both ends (not like a roll pin that you can hammer out)...anyone with a ph3 can have a look..........I'd show you a pic if i still had the pug.
As tom says, the ph3s are 1 unit, but only on the front, not the rear.
For the straps them selfs theres a from and till build code, so the from ones will be the complete unit.
Chris Wrote:As tom says, the ph3s are 1 unit, but only on the front, not the rear.
Thank f*ck for that! Was starting to doubt myself!
